Old 08-27-2024, 11:05 AM
joes455 joes455 is offline
Default Ac delete
Eventually will be installing Vintage Air for ac car . Can't decide if I want to go with a plastic or fiberglass delete box for now. Need some help with pic,pros and cons.
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 08-27-2024, 11:21 AM
7t4mula's Avatar
7t4mula 7t4mula is offline
I’m doing the same, replacing the old factory AC on my 70 Formula with a Vintage Air unit. I’m doing a resto-mod project and wanted to clean up the engine compartment…
I had my bodyman weld in a steel panel to smooth the firewall. I’m assuming this is what you’re talking about? He also welded the stud on the inside, for mounting the VA unit so you don’t have to drill through there. Looks super clean now!
ID:	639012   Click image for larger version
The Following User Says Thank You to 7t4mula For This Useful Post:
Thread Tools
Display Modes
