Old 11-01-2024, 05:20 PM
RocktimusPryme's Avatar
RocktimusPryme RocktimusPryme is online now
Default Hood webbing re-glue method
I’m not asking which product to use. That’s been covered.
I’m asking more how to do it. The hood on my 62 has come completely detached from the webbing and oil cans badly. I’ve attached two pictures. One is the hood sitting ambient. The other is me pressing down on the surface of the hood so that the original gluing meets.
I assume that position with the glue pressed back together is where I would want to be as that’s how it left the assembly line. How do I get the hood sheet metal to stay in place aside from me just holding it down until the new glue/caulk cures?
Or am I overthinking this and I should just remove all the old stuff and re-caulk it with it sitting where it wants to without me pressing on it or otherwise trying to hold it down.
ID:	642083   Click image for larger version
Old 11-02-2024, 02:41 PM
webfoot's Avatar
webfoot webfoot is offline
My 62 cat had the same problem. I chunked as much of the old stuff out of there as I could and used some black 3M goop I shot out of a pneumatic caulk gun. No more oil canning.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 11-02-2024, 06:02 PM
Sandbags?
Old 11-02-2024, 08:02 PM
Sandbags?
That’s not a bad idea.
I’m mostly curious from other who have done it before, especially any professional body guys if it’s worth trying to weight it down. Or do they just put the new glue in and call it a day.
I’m also curious how it was done at the factory.
Old 11-03-2024, 02:48 PM
On my 72 Lemans, I chose to just apply the material without trying to influence the surface. I don't think from the factory these two surfaces were a snug fit everywhere to each other. If you try weighing it down for a tight fit, it raises the chance of it coming apart down the road from heat and vibration anyway.
The Following User Says Thank You to tjs72lemans For This Useful Post:
Old 11-04-2024, 11:08 AM
Joe Joe is offline
Following this thread for sure. Will be removing the inner structure on a 67 GTO hood later today. To fix some high/low spots that occurred when I had a resto shop weld in a patch where the hood tach was.
Which you cannot get at with the inner structure in place. Then will have to re-glue it back in place prior to welding. What I have done prior to drilling out the spot welds was to put some 10/32 machine screws on each side of the hood to locate it in it's original position. Might even answer whether I have to put some pressure on it or not. Thanks
Old 11-08-2024, 10:20 AM
Flynbye's Avatar
Flynbye Flynbye is offline
Default Hood flutter
Back when I worked at a Pontiac dealer, many late 80’s Bonneville’s had a hood flutter problem. The foam adhesive separated just like yours.
There was a service bulletin that had us use a two part foam adhesive to repair. We just cleaned out as much as we could without damaging paint/primer, reapplied the adhesive, tripped the hood latch to the closed position, set the hood against the latch and taped the front sides of the hood to the fenders. Used 2” masking tape, tape one side tight, then have a helper apply pressure on the other side while taping it. Let it sit overnight and it was good to go.
I used the same process when I restored my ‘68.
The Following 2 Users Say Thank You to Flynbye For This Useful Post:
Old 11-11-2024, 11:46 AM
bill ryder's Avatar
bill ryder bill ryder is offline
factory built the inner structure, then applied the mastic kisses (that is what they look like) in the correct places, then placed the hood skin in the correct position and sent it all thru a curing oven.
"Bill"!
Old 11-19-2024, 06:53 PM
I got my SEM anti flutter foam, and the little gun to apply it (They are proud of those things). I was looking at it closer last night. Applying it without putting weight on the hood is not an open. While the hood looks perfectly fine from the top at a casual glance. The center of the hood where there is the medial ridge that runs down, is a good 1/2" separated from the webbing. That gap is too big to fill. The sides arent separated as far because the hood has a bit of a curve to it.
That center area also requires quite a bit of pressure to close the gap, so while I liked the masking tape idea, I just don't think I can apply enough pressure with the tape to close it. I did some googling and tried to find that service bulletin but couldn't.
I think I'm going to go get some bags of potting soil (because Ill use those afterwards and they wont go to waste) and try to strap them to the top of the hood and see if I cant get the whole thing to match the depth of the old glue/caulk.
The only other thing I could think is to try and not do it all at once. Start from the outside where the gap is less and glue it back together. Basically take it one hole in the webbing at a time. In theory by the time you get to the middle maybe it will be pulled closer. But I want to see how close I can get the whole thing with the potting soil first.
I will report back how it goes.
Thread Tools
Display Modes
