Old 11-05-2024, 03:12 PM
BigB's Avatar
BigB BigB is offline
Default Default Struggling with 1975 Firebird power steering and alternator configuration
I am restoring a 1975 Firebird Formula and unfortunately didn't remove the accessories myself. I also have multiple brackets. This is an A/C car that I believe has the 80amp alternator. I know the brackets on the power steering pump are the original, but cannot find any good pictures online, or diagrams to show which brackets to use and how everything mounts. I'm hoping someone here can assist with info and maybe take a quick picture or two of their setups for me if they are also using this power steering setup. Thanks in advance -B
ID:	642408   Click image for larger version
ID:	642409   Click image for larger version
ID:	642410   Click image for larger version
ID:	642411   Click image for larger version
Old 12-06-2024, 12:44 PM
unruhjonny's Avatar
I believe that 1975 used the same brackets as 1976-1978;
That alternator is absolutely wrong - maybe that's your issue?
What cranshaft pully(ies) do you have?
What water pump pulley do you have?
1970 Formula 400
Old 12-06-2024, 05:54 PM
Held for Ransom's Avatar
Also, what are the casting numbers on the inside of the 2 aluminum brackets (picture 2)?
So long, farewell.
Old 12-06-2024, 07:04 PM
unruhjonny's Avatar
I have come to understand that mis-matched pullies are THE biggest issue that people have with throwing belts (ect.)
1970 Formula 400
Thread Tools
Display Modes
