Old 09-11-2011, 09:35 PM
1963vert's Avatar
1963vert 1963vert is offline
Default door panels
the driver side door panel in my car is pretty ratty.
are the materials to redo it still available?
Old 09-11-2011, 11:05 PM
mechanickeith's Avatar
Yes!! Ames Performance has just issued the first catalog just for 61-63 Tempest cars. Lots of parts here!!
http://www.amesperf.com/index.html
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 09-11-2011, 11:30 PM
1963vert's Avatar
keith thank you for that.
Old 09-12-2011, 07:29 PM
Radman's Avatar
Radman Radman is offline
Ditto on the Ames catalog. I came up with a wish list that totaled over $1000.00 in the first 2 minutes.
Old 09-13-2011, 02:05 PM
GaryK's Avatar
GaryK GaryK is offline
Not sure if Tempest Panels are available, Lemans panels are. If you run into trouble getting them, PM me and I will give you a contact at Ames and PUI. If you send them your panels, they might be able to reproduce them for you, then offer them to others.
Its what my friend did with his 62 SD Lemans.
Gary
Old 09-13-2011, 04:17 PM
gstoib's Avatar
gstoib gstoib is offline
Just to add to what Gary K and Keith said, most of the places that advertise "63 Tempest" door panels actually only carry the LeMans panels with the carpet along the bottom. Make sure to clarify before buying.
Old 09-13-2011, 08:15 PM
1963vert's Avatar
here is what mine look like. do their colors match up?
[IMG] Uploaded with ImageShack.us[/IMG]
Old 09-13-2011, 08:28 PM
Is that carpet at the bottom? looks like a LeMans panel. You can request a swatch of material from Ames to see if the color is the same.
Keith Collier
Tech advisor
POCI.org
Old 09-13-2011, 09:05 PM
1963vert's Avatar
i thought the same too. the car is supposedly original. i will have to ask the po next time i am there working on it . i should check the other panel while i am at it.
the car has the round tempest tail lights and all of the tempest emblems. no lemans ones to be seen anywhere. will have to request the material and see
Old 09-13-2011, 09:14 PM
It could still have the upgraded interior without it being a LeMans. The only difference is the badging & tail lights.
Keith Collier
Tech advisor
POCI.org
Old 09-13-2011, 10:26 PM
1963vert's Avatar
upgraded interior? what else would it have?
Old 09-14-2011, 01:48 AM
I dont have an accessories booklet for the 63's, BUt you could order a car with just about anything you wanted!! You had a base interior, usually cloth (standard) & then you had the delux interior, usually Morrokide Vinyl (option). You could order all the LeMans options & have it put on a Tempest. The only things not available without it becoming a LeMans is the tail lights & the badging. Need to order a PHS listing on your car. This will tell you exactly what was on the car from the factory. It will also tell you where the car was built, where it was shipped, etc, etc. PHS for Pontiacs is concidered the "Birth certificate" for the car.
http://www.phs-online.com/services.htm
Keith Collier
Tech advisor
POCI.org
Old 09-14-2011, 09:27 AM
beemergary's Avatar
You can have vinyl paint mixed to your color choise.
