Old 09-11-2011, 09:59 PM
1963vert's Avatar
1963vert 1963vert is offline
Default convertible owners
i have way more time than money. that being said
have any of you redone your convertible top on your own? any pointers or things to look out for? should i just forget trying this at all? thank you for any insight.
Old 09-12-2011, 07:28 PM
Radman's Avatar
Radman Radman is offline
I was planning on doing my own. Then I got the body manual and read the instructions to change the top. If you have no experiance with uhpolstery, and I do not. Pay someone who does to do the job. Getting a top on without wrinkles is not as easy as it sounds. You are better off paying the money on this job.
Old 09-12-2011, 07:42 PM
stevep's Avatar
stevep stevep is offline
Default I agree!
Let the pros do it.
Old 09-12-2011, 10:54 PM
1963vert's Avatar
i looked over the procedure last nite. i believe that is the end of my diy convertible top jones.
Old 09-13-2011, 03:00 PM
JC61's Avatar
JC61 JC61 is offline
I concur ^^^
Name:	1961 Pontiac Bonneville Convertible 067.jpg
Old 09-13-2011, 04:21 PM
gstoib's Avatar
gstoib gstoib is offline
That said, make sure you find a first-rate shop that does tops all the time. I had a professional shop botch a top years ago. Particularly make sure they use the correct weatherseal at the top of the windshield. Another area that is sometimes done wrong is the tension on the top fore and aft. Too tight and it'll take Arnold Schwarzeneger to close the top clamps.
Old 04-17-2014, 07:57 PM
TomMcCrea's Avatar
TomMcCrea TomMcCrea is offline
Last summer I bought a new top and pad for my '63 and had planned to do it myself, until I read about how it is done. There is an upholstery lady just two miles from my house so I asked her if she would install it and she said yes, for $500. I dropped off the car last Friday so she and her husband could do it over the weekend. She called Sunday evening and said it was finished.
The job looked pretty good and I was happy not to have gotten into it myself. When I got home I tried to raise the 1/4 windows and found that they dig into the new roof rail weather strips and found the shop manual saying the "Male Hinge Assy" needs to be adjusted. These folks are not mechanically inclined so I figured I would see what is involved. My biggest concern is, can the adjustment be made now that the top is stapled in place? Has anyone every made this adjustment?
Old 04-17-2014, 09:32 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
If I understand your situation clearly the answer is probably not. All of the folding top frame to side glass "rough in" adjustments should have been done prior to taking the car over for a new top. There is ( I think) an adjustment at the pivot point mounting (each side) to inner quarter sheet metal where you might be able to slightly lower the effective height of the quarter glass.
How did this happen in the first place? Had the entire folding top assembly been taken off of the car?
Peter Serio
Owner, Precision Pontiac
