Old 10-18-2021, 08:47 AM
DM3 DM3 is offline
Default Questions: Rear Window, A/C and Rack and Pinion
I have a few questions:
1. Rear Glass: I am having my scratched rear window replaced tomorrow. Looking at the existing installed window, there is a lip. I added two pics, can you tell me if that looks correct.
2. My car didn't have a/c. I am looking to add an aftermarket a/c system. Do I have to remove the fender to install this system like you have too, to install the heater box?
3. I am also looking into power rack and pinion system. CI sells a kit, but it states not for original pontiac motors. Has anyone installed a R/P kit that was bolt on without frame modifications?
Thanks for the help!
DM3
ID:	575474   Click image for larger version
IG: #67MoparBird (Follow my rebuild)
1967 Firebird 400
Appeared on Gearz, Season 16, Episode 1, Segment 'What Are You Working On?'
Old 10-18-2021, 10:00 AM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
I can't help with the first 2 but I've seen nothing good about putting rack and pinion systems on a Firebird. The kits are all designed around chevy engines and mounts. If you're on facebook check out the post made by Steve Vanderbilt here. https://www.facebook.com/groups/1612...20and%20pinion
67 Firebird Convertible
