Old 12-14-2019, 12:44 PM
cnc's Avatar
cnc cnc is offline
Default Headliner
I'm in the need of replacing the headliner in my car
If I'm not mistaken the interior is Saddle or is it dark Saddle.....and it's perforated
I can't seem to find it in the 70-73 area but I think I've seen it fro 74
Is I possible this car got a 74 headliner
It's got a 74 subframe in it...so I've discovered
Who has a decent headliner I can reglue to my board in the car...thanks for any input
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 12-14-2019, 06:07 PM
cnc's Avatar
cnc cnc is offline
I have asked this prior with little resolution just hoping things may have changed ...lol
When. I mention about this being 1974 I'm only relating to the material cause 74 came with retractable shoulder restraints if I'm not mistaken...I do not have those since the car is a 73
Old 02-10-2020, 05:52 PM
gassman_67's Avatar
gassman_67 gassman_67 is offline
I just got my 67 GTO dark aqua perforated liner from SMS, It was absolutely spot on with what came originally.
https://www.facebook.com/KauffmanRac...6873234225938/
KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9".
552HP 594 TQ
Old 02-11-2020, 12:10 PM
78w72 78w72 is offline
just an FYI: PUI makes a ABS headliner without the seatbelt cutouts with the perf padded vinyl attached. if you cant locate just the vinyl, its another option & priced very reasonable.
Old 02-12-2020, 11:45 AM
HWYSTR455's Avatar
THIS! Yes, best route to go, and you can have them provide whichever headliner you need that will cover it properly.
