Old 01-24-2020, 06:24 PM
cnc's Avatar
cnc cnc is offline
Default Parts Place seat belt buckle kit
Anyone use these..I'll looking at the kits and see to designs
I'm trying to measure and compare to there measument size but I'm not sure where to measure from ...they say distance between the pins ...but mine are broken so not sure where they mount in the buckle
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 01-24-2020, 06:50 PM
Held for Ransom's Avatar
http://www.forums.maxperformanceinc....d.php?t=810022
Look at the buckle and click on my eBay link in post to compare the two designs.
So long, farewell.
Old 01-24-2020, 07:16 PM
cnc's Avatar
cnc cnc is offline
Thanks HFR
So I went out and checked my rear belts one was still good except one pin slightly broken to hold it down
Anyway these are the measurements I got slightly different from what they post for first design
1.30 and 0.90
I think I want first design as we r close...
ID:	529874   Click image for larger version
