just saw a mint 1980 t/a 301 4bl car
saw a nice trans am today completely restored to the tees , when he stared the car a lot of black carbon came out of the tailpipes i have no issues with the body and the interior , what should i check or worry about the engine . he said it was also rebuilt
I would be concerned with visible smoke and leaks. It's a carbureted vehicle, so there will be a fair amount of carbon in the exhaust system, even with a healthy catalyst.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
it seemed to run smooth after the start up , there were no visible leaks . could it be to fuel and the carb needs to be adjusted
You are looking to buy the car?
_____________________________ She woke up sunny side down and I was still thinking I was too proud to flip her over |
If the car is a cherry original, the carb is likely untouched, and needing attention, especially if starting up cold.
My gut feeling is, the current owner doesn’t want to touch the carb, afraid of making it worse...
will try and post a photo |
is this correct
With regards to black soot coming out the exhaust - I'd warm up engine and so its idling around factory stock (750-800rpm?) and check the engine vacuum.I would think idle vacuum reading should be around 18-20? and nice and steady (at idle). See how vacuum responds to engine rpm. Check water temp- should normally be around 180-190 at idle? Pull driver's valve cover cap and inspect underneath ? signs of milky white residue might indicate engine problems (blowby). Pull passenger pcv vent tube and check inside tube for wet oil - could indicate engine has some blowby. Let engine warm up and then rev engine with valve cover cap pulled - check if you see any smoke coming out. Pull air cleaner lid and check air filter - see if its oily - check where pcv tube comes into air cleaner - again , is it oily? is pcv breather oily? These checks can help give you some ideas of engine condition. All engines will have a bit of blowby and older high mileage engines will usually have more blowby. Blowby can come from piston rings, valve seals , bad pcv valve (and other areas). It is also possible the engine needs a tuneup - possibly plugs are fouled and / or engine timing is off. I thought factory started putting caps on qjet idle mixture needles in late 70s. So, could check if idle mixture need caps are there ? From what I have read factory typically set idle very lean on these late 70s qjets.
yes, those rivets are original for the final years.
the car is fully loaded and fully restored i sent him a offer ,lets see what happens
one more thin the car is missing the duct work from the air cleaner ,look at photo is the the correct duct work for a 301 n/a |
The standard 301 uses the smaller duct hose and elbow adapter, but of course, these aren't repro'd yet.
https://www.firebirdcentral.com/1979...p/10007530.htm |
the air cleaner on the car looks different with a wider boot
Yes, they've used an earlier Pontiac base, not the angled 301T base. If that even fits the 301 correctly then the rest of that larger ducting can be sourced as usual, the flex hose drops in and out of availability.
you got a great eye , so is this from a 79 301
Actually, it hasn't got the slots for the clips that I thought it had to attach the adapter so it may be the original type. But it takes a hard to find round-to-oval ducting that also isn't available. I'm not sure if a 4" ducting would squeeze out of shape and stretch to fit of not. There's a few different 301 snorkels over the years, plus the Turbo downpipe style.
Looks like it should use this hose, and I don't see the plastic ductwork over by the fender.
80 ta air cleaner by grand73am, on Flickr
Steve F. |
If it's 'totally restored' he may have one of those 'factory re-conditioned' carburetors on it since many don't understand or want to learn anything about quadrajets.
If it has one of those on it, it's likely junk. I had one for a while and it would literally cause your eyes to water and clothes to stink.
Greg Reid Palmetto, Georgia |
i know one that is restored and orginal for sale |
Yes, that's what that drawing is for (not a turbo) .
Steve F. |
