Old 02-28-2020, 01:07 AM
ZeGermanHam's Avatar
Default Dash Clock Rebuilding
Hi folks. I have a friend who is wrapping up the last little details with her '64 GTO restoration. She would like to have the dash clock rebuilt before installing it (unknown if it worked previously, as it was one of many pieces in a box).
Does anyone here have a name for people/companies who are able to rebuild the clock? Thanks!
1998 BMW 328is (track rat)
Old 02-28-2020, 09:48 AM
65 421 TODD's Avatar
65 421 TODD 65 421 TODD is offline
Precision Pontiac did mine, excellent job!
Old 02-28-2020, 10:20 AM
1969GiPper 1969GiPper is offline
Did they convert it to a quartz (silent) movement or rebuild the original mechanical movement (that you can hear ticking)?
Old 02-28-2020, 10:38 AM
428goat 428goat is offline
Bought a DIY kit about 24 years ago for a quartz rebuild. It took about 2 hrs if I remember. Don’t need any special skill.
Still running perfectly. Sorry can’t remember where I got it from.
Old 02-28-2020, 11:51 AM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
I did one for a friend on his 67 a few years back. I tried to fix the original, but the material that triggers the clock to rewind (or keep going) was like a lint type material and it was basically wore out. I had that clock apart several times and ultimately couldn't find anyone who could supply the material. I finally put a quartz movement in and it has worked flawlessly since.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
Old 02-28-2020, 11:57 AM
Do you recall where you got the quartz movement from? If it's easy to convert, my friend may want to just do it herself.
Old 02-28-2020, 02:13 PM
mrennie's Avatar
mrennie mrennie is offline
Instrument Services sells quartz conversion kits. I installed one on my clock and was tedious but straight forward.
https://www.clocksandgauges.com/quar...rsion-kit.html
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Old 02-28-2020, 04:16 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
Depends what you’re looking for. As stated, a number of places do quartz conversions and also sell DIY kits. Do a google search. If you want originality of the jeweled movement which makes the tick sound when it resets, try this place. https://omicronclock.auctivacommerce.com/Default.aspx
Besides the usual cleaning, lube, etc., this is done: Includes the correct Pontiac power terminal plus we have added a rectifier diode which helps prevent the contacts from arcing which is a major cause of failure in these clocks
Old 02-28-2020, 08:57 PM
nashcar nashcar is offline
Had mine converted to quartz by Instrument Services I think for $65.00. I figured the time it would take me to do it made it worth paying them.
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
Old 02-28-2020, 10:42 PM
Thanks for the info everyone. Sounds like there are options, and frankly, converting to quartz is likely the easier, cheaper, and more reliable choice.
Old 02-28-2020, 10:51 PM
6 Grrrs's Avatar
I'd have to dig thru papers to find exactly where I got it. It was not instrument specialties.
Tod Hoffmann
2002 Honda VTX1800C
