Old 03-10-2020, 02:54 PM
grd777 grd777 is offline
Default need help with my radio
as you know i have a 81 turbo trans am . when i purchase the car ,i got a delco am/fm radio in a box . the last owner had a aftermarket radio in the car and cut of the original connectors . can some one show me some photos of the connector look like and how to install this radio
Old 03-10-2020, 04:04 PM
burd's Avatar
burd burd is offline
Black, white and blue connectors. Delco makes a kit. It’s cheap, comes with crimp on ends that go in the plugs. Your GM manual should show the hook up. It’s usually stamped in the case what wire is what.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
F ire B irds
Old 03-11-2020, 10:03 AM
78w72 78w72 is offline
https://www.ebay.com/itm/Plug-into-F...kAAOSwyhBcbC~u
Old 03-11-2020, 10:46 AM
Grand73Am Grand73Am is offline
Originally Posted by 78w72 View Post
Those on eBay may not be the correct ones. If your radio looks like my radio in the top pic, then the connectors look like the ones in the other pics. Here's a link to ones that will work. It shows 4 connectors in the listing, but only 3 are needed...the ones with 4 contacts each. https://www.ebay.com/itm/DELCO-GM-GM...UAAOSwNlleDlwP
007 by grand73am, on Flickr
s-l1600 (3) by grand73am, on Flickr
s-l1600 (4) by grand73am, on Flickr
Steve F.
Old 03-11-2020, 11:06 AM
the connector i linked to will work for the style radio you pictured as well as many other years. i have the same radio as that in my 78 as well as the digital tuner type for my 81 & use the connector i showed, it works & installs perfectly.
the new reprod 1 piece connector simply combines all 3 of the individual ones you show into one connector. look closely at the one in my link, it has the same 4 contacts per section as the individual ones you showed & lists what each color wire is for. just a easier/cheaper way to repro them.
Old 03-11-2020, 11:12 AM
Okay great. I see what you mean. Thanks for pointing that out. Not looking like the originals, I didn't even notice they combined them into one plug.
Steve F.
Old 03-11-2020, 11:27 AM
yep, i was curious about that too when i saw these 5+ years ago & asked the seller who confirmed they work for all these style radios. from 75 or 76 to the early 90's GM used the same connector on their radios.
Old 03-11-2020, 02:32 PM
Good to know. Do you know what the extra connector with 2 contacts is for?
Steve F.
Old 03-11-2020, 02:38 PM
not exactly sure but i think they are for later models that have an extra feature the older radios dont have, like maybe the led light fader? just a guess.
Old 03-11-2020, 03:15 PM
can you let me know what eack connoctor does
Old 03-11-2020, 03:38 PM
it should be stamped on the radio.... or look at the link i sent for a new plug, it explains what each color wire does & where it goes.
Old 03-11-2020, 03:44 PM
ok great
Old 03-11-2020, 04:41 PM
Probably so. Glad I'm not the only one that didn't know what it's for .
Steve F.
Old 03-11-2020, 07:11 PM
Held for Ransom's Avatar
Interesting on the extra Yellow wire in your Black connector plug into radio. Most were a Pink wire for power antenna. Here is the stamped diagram...
So long, farewell.
Old 03-11-2020, 09:09 PM
You're right, I have seen pink for that too.
Steve F.
Old 03-11-2020, 09:56 PM
burd's Avatar
Here’s the Delco kit. They were $10.
F ire B irds
