Wanted 1966 OHC Parts
Needing the following OHC Sprint parts 1966:
(1) Frame Mounts (2) Throttle cable (3) Dip stick tube (4) Choke Stat NOS or good used (5) Oil Cap (6) Head pipe (7) Exhaust shield (8) Distributor (9) Air Cleaner or just the base (10) Fan spacer (11) Correct Harrisson radiator for a manual trans (12) Cam and timing gears (13) Cam seal (14) Fuel Pump Please email nescgto@gmail.com or call 508-808-1290 Thanks Alex |
1. Frame brackets are somewhat hard to come by.
2. Same goes for the correct throttle cables. 3. Upper or lower stick/tube? 4. Choke I should I have. 5. Oil cap also should have a few different. 6. Head Pipe? are you talking the "Y" if so I have a 1 decent one left. 7. Exhaust Sheild? not sure what that might be. 8. Distb, I have used and reman but they can also be had from auto store. 9. Pancake air breather I have one decent one left complete unit will not seperate. 10. I think I might have a spacer but the '66 did not use one. That was a '67 FB pt. 11. I have an oem MT rad for '66 that is a CORE and I have one re-cored ready to use but it has ports for AT cooling. The only diff as you may know are the cooling ports but since the '66 was an air cooled AT I never understood why some rad had them? 12. I have one E cam left, just not sure If I want sell at the moment. However you can get Cams from Kanter Auto. Which gears/sprockets do you need? 13. Cam seal I have. 14. Pumps I have as well oem & rebuildable aftermarket units. Ill pull out all that I might have and get you more info. Cheers
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
PM sent
I think I have most of that stuff too
got a mint 66 intake exhaust Y pipe setup but dont want to seperate I used to repro the Y pipes out of 14 gauge alumnized,still have jigs,parts etc but lost access to a bender.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Parts are on the way.
Ill PM you the Tracking # Thanks again.
