Old 08-22-2019, 01:35 PM
8LUG 8LUG is offline
Default 1964 fuel pump sealing washer
Did they use the sealing washer in 1964? Did both bolts have the washer or just the back one
Name:	fuel pump sealing washer.jpg
Old 08-22-2019, 03:41 PM
Dick Boneske's Avatar
The bolts have a shoulder. I've never seen a sealing washer, but that would be a good idea for the back one. I've used RTV on the back one to seal for oil leaks.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 08-24-2019, 02:36 AM
Goatracer1 Goatracer1 is online now
Both of my bolts have soft metal washers.
Old 08-24-2019, 10:39 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
1964 GTO Very Low mileage Survivor.
Rubber washers.
I would assume the assembly line workers would only have the 12 point bolts with rubber washers to install on both sides of fuel pump. Less confusing, no leaks.
Chris.
Old 08-24-2019, 12:40 PM
Default fuel pump washers/with rubber
Thanks Chris, for your answer & picture, John
Old 08-24-2019, 01:42 PM
60sstuff's Avatar
Goatracer1,
Would you post a couple photos of those “soft metal washers” on your bolts.
Thanks, Chris.
Old 08-24-2019, 02:25 PM
Are they the same copper washers used on the valley cover bolts?
BONESTOCK GOATS
