Old 09-11-2019, 03:09 PM
Shift'n Gears's Avatar
Shift'n Gears Shift'n Gears is offline
Default 1970 TA block codes
Has anyone ever heard of a 70TA with a WT block code? I thought that all TA's had a WS code and that WT was for a GTO.
1978 Y84 4sp
1979 T/A 400 4sp Blue/Oyster (special order)
2000 T/A WS6 6sp Black/Black
Old 09-11-2019, 04:03 PM
WT would be for a non-RA block.
All TA's had RA engines, so, no WT would not be in a TA.
(WT could have been in a Formula though)
Old 09-11-2019, 11:57 PM
Thumbs up
Thanks - that's what I thought. Looking at a 70 TA, guy was trying to tell me it might be the original block but it is a WT, All the research I did said that it was a GTO block.
1978 Y84 4sp
Old 09-12-2019, 10:52 AM
Formulabruce's Avatar
WT was Factory installed in a 1970 Formula 400 4 speed, with #12 heads.
Old 09-12-2019, 11:09 AM
unruhjonny's Avatar
unruhjonny unruhjonny is online now
the WS/YZ are both 'L74' RAIII which were the 'base' engines for the Trans Am;
The WT/YS were both 'L78' which were one step down from the RAIII; this was the base engine for the GTO & Formula 400.
1970 Formula 400
