SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
1965 Pontiac Tripower
1965 Pontiac Tripower, needs restored, carbs are correct. Asking $950 picked up in Duncan Oklahoma.
It appears the water crossover is drilled and tapped on the right-hand side. I have not seen that on a '65. Was that factory on some manifolds or done later?
should the center carb have the idle vent on the air horn?
I believe the center carburetor to be correct. The bowl casting number is 7019929 and the airhorn is identical to airhorns’ on my other 65 tripower setups. The center carb was off of an automatic car as the accelerator pump arm has the part that engages a vacuum switch. I included a better picture of the airhorn for the setup that is for sale along with pictures of my other 65 tripowers’ airhorns to compare to. As far as the hole in the water crossover, I am not sure. It is threaded so it can be plugged if not used.
Asking $800, would still prefer pickup but might ship. Carbs and intake would ship in separate boxes.
It was a carry over thread hole from 1964.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
The Following User Says Thank You to 60sstuff For This Useful Post: | ||
“Just a bystander”
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post: | ||
Still have this. Pictures of the date code and part number of the center carb are attached.
$775 plus shipping
$750 plus shipping.
‘65 Tri-power
PM sent
Carbs and intake are sold.
