i'm considering chaining mine to the barn post next to it
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
I replaced the manual tank drain valves with solenoid valves on both of my compressors set up with a push button to energize. I purge them every time I turn them on and after I'm done for the day. Make sure you get one rated for the max pressure of the tank. https://www.mcmaster.com/4738K138/ |
Had a neighbor explode his horizontal tank. The end cap blew of, shot 50' into a telephone pole like a sharp edged discus.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
That is a super trick drain valve .... might have to get me one of those.
WOW....I'm going to rethink my setup in the garage! I have to reach over mine to throw the wall switch off....yikes. My old girl is about 50 years old too.
30 gal. horizontal unit I got as a B-day gift as a kid. I normally drained the tank after each use, but I didn't the last two times cause my back was hurting : ( Excuse me while I walk out there now to open the valve...wish me luck |
Was just looking through some of the data. Appears a high proportion of the explosions were small horizontal units, about 80% of the time the cause attributed to lack of maintenance (draining). I'd guess the horizontal tanks have the water lying in a larger area in the bottom that leads to more rust than you would get with a vertical tank. Some tanks exploded because people plugged the drain valves (because they were leaking). Some are not ASME certified.
Saw a LOT of no-name, cheap compressors in the pictures. Just looked around ... not many of the small horizontal units are ASME certified, and the ones that are, are priced accordingly. Was thinking about replacing my old 5 gallon portable air tank with an ASME unit ... can't find one so far. If I'm not mistaken any compressed air tank used in a commercial environment in the US has to have ASME certification. Last edited by dataway; 01-14-2021 at 01:46 AM. |
Sort of a timely thread for me. I've been using a DeWalt 2 HP vertical that I bought new- it lasted about 4 months and the electric motor failed a couple of weeks ago. This shut down my 5 axis mill for about 2 weeks to get a replacement compressor. No more Home Depot compressors for me so I upgraded to a 7.5 HP Kaeser. It's interesting that the better made compressors go to great lengths to try and manage water in the tank, this one is a "dry tank" which means the dryer and refrigeration occur before the air gets into the tank- not after. Also, an automatic tank drain as well as a dryer condensate drain.
The day after the install, I was running my mill and listening intently to the cutter, and I thought I heard my front office heater kick on. Nope it was the compressor. I could barely hear it. Worth every penny right there. One last thing, the better compressors epoxy coat the tank insides, which seems like a pretty good idea to me.
1964 Catalina 2+2 4sp, 421 Tri-power 1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM, Holley EFI, DIS ignition. 1969 GTO 467, Edelbrock 325 CFM, Terminator EFI 1969 Firebird Convertible |
Definitely a case of "you get what you pay for"....at least in this case : ) |
Yep, the only way to go is dry the air before the tank. My whole setup is based on that principle ... and more separators and filters after the tank too. Haven't gotten a drop out of the tank vent since I made these modifications to a new IR compressor.
Is that Kaeser a rotary? |
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
always drain my steel ones and have an aluminum tire filling tank so i dont worry so much about that one
Frank Szymkowski 1969 GTO Judge Warwick blue/blue, RAIII, 4 speed, tach/gauges, Safe T track, 3.55's, ps and radio. 1971 Torino 351c 4v GT convertible. White on white with black interior 4 speed, shaker, am/fm, ps/pdb, buckets/console, ac. One of 26 made |
Well, that's scary..I have that exact compressor and it's at least 20 years old. It has already developed a pinhole in the bottom from rust. It stopped itself back up which suggests to me that there's a significant amount of rusty sludge down there. I need to find a good tank for it...but where can you purchase just a tank?
Greg Reid Palmetto, Georgia |
Places like Northern Tool sell ASME rated tanks .... probably $5-600 for a 60 gallon. If you have a good compressor head it's worth replacing the tank. If you have a old rebranded compressor probably makes more sense to just replace the whole thing.
Most of the store brand stuff is all made by the same companies with slightly different options and different paint. When you get up to around $1600 (5hp, 60gal) you start seeing a better quality compressor, but still typically India made compressor head, US ASME tank. Around $2000 you start getting into some US made compressors, same tanks as the $1600 compressors ... but better compressor head, maybe even US made. Names like Quincy etc. I've been real happy with my IR. It's one step above store brand, and rated as a "commercial" compressor, but certainly not the quality of the old US names, has the typical India produced cast iron pump. |
We used Kaesers at work for a variety of applications, they are on a completely different level than the Homey Depot Chinesium stuff you buy for $300-500. Lots of engineering went into them, they also will service them for you on the regular according to schedule if you use them often enough (as we did running a cryo-plant). It 100% is a case of getting what you pay for. You're more likely to have problems with the controls hardware than the motor or pneumatics on one of them.
Title of thread is drain and inspect compressor tank. I think the drain part has been pretty well covered and I appreciate the ideas for auto drains and drying the air. How about inspecting the tank before it explodes? Obviously, perforation on the outside or a rough surface or a tiny leak is a ticking time bomb. Any other suggestions for a more routine inspection of the tank? When I drain my tank, rusty water always comes out, but if the tank is un-painted, untreated, that probably doesn't mean much.
Not much you can do except pull a plug and use a remote inspection camera.
Not sure what kind of drain setup you have, I use a full 1/2" NPT with a ball valve ... the ball valve is key ... you can whip the valve wide open and see if it carries particles of rust out with the water mist .... might want to run the pressure down low before doing this. If you see flakes of rust coming out you are probably in the danger zone. |
#38
My compressor is old. But a 80 gallon ASME tank, 2 stage, sold by Grainger. Dayton brand, manufactured by Campbell Hausfeld. The drain is a ball valve, but only 1/4" NPT. Too small to get my camera into. Plus you would be going up through the bottom and probably not be able to see the real rust area. Possibly I could put a camera through the outlet of the tank and look down toward the bottom. The outlet is 3/4" NPT.
#39
This is taken from the site, Practical Machinist, and is the opinion on older air receiver tanks from a mechanical engineer. This is the link to the whole discussion, which is quite lengthy. It covers air tank failures on all types of equipment, including the air cannons used in the Punkin Chunkin competitions:
https://www.practicalmachinist.com/v...eplace-384769/ Quote:
#40
I just read the first sentence and it told me pretty much everything
"We've had quite a few threads on this 'Board discussing used/old air tanks." That's the problem right there LOL |
