Old 11-07-2020, 08:35 PM
grd777 grd777 is offline
Default Trying to figure out where to mount my coil braket
Can’t seem to know where to install it
Old 11-08-2020, 11:57 AM
3tas4me's Avatar
3tas4me 3tas4me is offline
Year?
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Old 11-08-2020, 01:33 PM
Originally Posted by 3tas4me View Post
Year?
1972 firebird formula
Old 11-08-2020, 03:57 PM
njsteve's Avatar
njsteve njsteve is offline
Did it have unitized ignition originally?
Old 11-08-2020, 04:46 PM
No I have the original date codes distributed. Is that odd for my year
Old 11-08-2020, 06:32 PM
Formulabruce's Avatar
Mounts to the throttle bracket, which is bolted to the intake, DS BEHIND air cleaner. Pics are in your ass y manual, which you did buy, right?
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 11-08-2020, 07:10 PM
Sorry not yet. Not sure which one to buy. Thanks
Old 11-09-2020, 07:51 AM
Norwood's Avatar
Norwood Norwood is offline
Maybe the one for your year and model of car would be the one.
The Following User Says Thank You to Norwood For This Useful Post:
Old 11-09-2020, 06:24 PM
that i know how about this one , or is there a better one to buy.
sorry about all these question , but i can only work on my car late at night since my younger brother ( 53) is dying of cancer and i spent a lot of time with him now.
i promise i will buy a manual , just want to get the best one out there
cheers to all the guys that have helped me along the way
Name:	IMG_3965 (002).jpg
Old 11-09-2020, 09:15 PM
njsteve's Avatar
1972 was a weird year. It uses a different bracket than the 70 and 71. Look for a 73 or 74 (pre HEI) bracket. They are pretty much the same as the 72. The reason for the change was that the 72 intake manifold had a slight alteration to the intake runners and the heat riser which forced them to alter the throttle cable bracket mounting points and thus the coil mounting spot.
The 1972 coil mounts to rearmost holes in the driver's side cylinder head and NOT The throttle bracket like 70 and 71.
ID:	553540   Click image for larger version
ID:	553541   Click image for larger version
ID:	553542   Click image for larger version
Old 11-09-2020, 09:39 PM
thank you sir
i guess i bought the wrong bracket , must be a 71
Name:	IMG_3966 (002).jpg
ID:	553549   Click image for larger version
Name:	IMG_3967 (002).jpg
The Following User Says Thank You to grd777 For This Useful Post:
Old 11-09-2020, 09:42 PM
I am not so sure that the coil bracket is the same on a 400 vs 455 in 72. Obviously ignition plays a part. I seem to recall having 2 different brackets.
Old 11-09-2020, 09:45 PM
thank you sir
That bracket is just like Steves, take out bolt and slide it on the intake stud
Old 11-09-2020, 10:53 PM
I think that bracket is made for bolting to the throttle cable bracket.
Is there a part number on that coil bracket?
Old 11-09-2020, 11:12 PM
i think u are correct , no part number
Old 11-10-2020, 02:45 PM
unruhjonny's Avatar
I have been trying to save pictures of correct/untouched stuff, and figured these images might be of interest to you;
unrestored/untouched 1972 Pontiac 400 with a points distributor (unfortunately the images are a bit small).
oh!!
How about this!!
Name:	1972 400 005.JPG
ID:	553575   Click image for larger version
Name:	1972 400 006.JPG
ID:	553576   Click image for larger version
Name:	1972 400 009.JPG
ID:	553577   Click image for larger version
1970 Formula 400
Old 11-11-2020, 12:43 AM
oh!!
How about this!!
thanks for all these photos it is a great help . the bigger photos is what i need to do , but the bracket i got is not exactly like the one in the photo
Old 11-11-2020, 11:09 AM
unruhjonny's Avatar
I am in Canada;
I have some spare coil brackets;
Shoot me your jumber via pm and I can send you pictures of what I have.
1970 Formula 400
Old 11-14-2020, 11:42 PM
Held for Ransom's Avatar
grd777, your bracket looks like a pre-'72 unit. If I get out to storage in the next week, I'll try to get pictures of a '72 and a '73-4 bracket.
So long, farewell.
Old 11-15-2020, 06:57 AM
That’s what I thought. Do u have one for sale
