Molnar 4.65 crank or larger crank builds
I saw on Molnars website a listing for a 4.65 crank that they say fits the stock 400 block
anyone using this or know of anyone using this or built one? I see 4.75s listed by other vendors and at one time thought 5" was an option price is the same as their other cranks too (maybe the 5" is custom and not in the same) 401-4650RC6F is the part # Anyone have a 5" stroke build? is that only possible with a tall deck aftermarket block? my thought is if crank prices are the same why not put the bigger arm in now and save bores for later.... email response: The crank should work fine in your stock block. I checked with Mr. Molnar to be sure and he said that as far as he knows these cranks have all been going into stock blocks and he has not heard of any problems. Sorry but I can not recommend any particular builder. That crank is meant to be used with any of the Molnar Technologies big block Chevy rods listed on this page: https://molnarrods.com/pontiac-400-crankshaft You need to match the crank stroke and rod length with the piston you want to use. Most of the pistons for this combo have to be made as customs so you have a few different choices in rods. |
The Following User Says Thank You to Don 79 TA For This Useful Post: | ||
Generally the 4.5 stroke doesn't work for poop in a performance build using a stock block. I'm thinking any stroke longer than that would be worse. But they can make a crap ton of torque..... JMO
I agree with paul on this.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
i just never saw this stroke before and based off their response i thought it was interesting as i've never heard of anyone using it but i'd imagine the torque would be so nice to have |
even on aftermarket blocks there have been some issues with the 4.75 (hooter) has some street car experience and went with a 4.65 during a rebuild, i think. the .1 difference is a lot of piston left in the bore. I believe there are more than a few RACERS that are in that 4.75 range. Wasn't that tall deck Alaskan gto even larger with a billet crank, many moons ago?
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
Wrist pin hole will be peeking out of the bottom of the bore.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
I believe Hooter went with a 4.375 Molnar . Im debating this as well, I may just go 4.35 Eagle instead of a 4.5 for an IAII.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
4.65 isn't uncommon in Pontiac "big power" builds. Usually reserved for heads up class racing where power is the number one priority.
We've built some fast 4.35 stroke combinations. Seems to be a nice compromise.
Sales volume withstanding,
Aftermarket blocks could be cast with extended cylinders in the crankshaft area Wouldn't have to be the whole circumference Could be just like the shape of the piston skirt that normally drops out of the bore to keep off the counterweights like .100 at the pin and .300 on thrust areas Whatever the numbers are basically get the bottom of the bore down as far as possible with emphasis on thrust areas maybe notched for the rod
A man who falls for everything stands for nothing. |
Stock block? |
I believe the Alaskan GTO was 600+ cubic inch. 5 inch stroke. The tall deck blocks were cast with a raised cam tunnel. Not sure what the largest stroke is without running into interference problems between the rods and cam On a standard cam location
Last edited by Kevspontiacs@aol.com; 01-15-2021 at 06:53 PM. Reason: Driving and not paying attention to what I was posting Lol |
After my experience with Molnar (Chinar) and the money i lost and the lies and lack of customer service.
I wouldn’t recommend them for anything. F em
It is easier to fool a man than it is to convince he has been fooled |
The Following User Says Thank You to 68azbird For This Useful Post: | ||
From experience, a 4.75 arm is not a great choice for a street car that gets driven. I tried that and it scuffed the heck out of the piston skirts. I’m now running a Molnar 4.375 crank. Piston stays in the bore way better.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
Thanks for correction Hooter
Both but not sure if the stock block combos would be considered "fast" by definition.
i was just shocked when i saw that crank size and oddly never heard/saw a build using it i wish we had some big bore aftermarket blocks like the BBC has |
We ran an IA II at 4.425 with a 4.500" stroke. No issues with the combination in general, making around 1500 HP spraying the hell out of it. Drag race only of course. Not much piston life with the long stroke. Skirts would collapse as the run numbers increased. No other issues attributed to the large bore or long stroke. Bearings were fine, no block failures. Usual head gasket issues in the center after 20-25 runs. Hard insert had not been developed when we ran this combination.
I'm building a 4.5 stroke aluminum block engine now. Using a 6.800 rod in it.
Thread Tools | |
Display Modes | |
