Old 07-30-2004, 06:23 PM
shotgun shotgun is offline
PY Staff -Tech
I was mocking up a 2 1/2 X pipe system on my 70 Sport.The question I have is the muffler brackets.
The supplied brackets for the muffler don't have the cresent piece that bolts to them when compared to the stock pieces.
This is the piece the U of the clamp would attach to.
Are they supposed to come in the kit?
If not,it looks as if the clamp was mounted upside down it would work,anybody do this?
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date 10.00@130.92 mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
PY Staff -Tech
Old 07-30-2004, 09:32 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
If you just got a X kit there is no hardware included. If you got an entire exhaust system then you should have left and right muffler hangers as well as tailpipe hangers.
The muffler hangers would look like this.
Old 07-31-2004, 06:21 AM
PY Staff -Tech
I got the whole exhaust system, x pipe,mufflers,tailpipes etc.
I got those those hangers(pictured),but they are missing a part compared to stock.
If you don't use the stock piece that is missing,how are they mounted?
Old 07-31-2004, 01:44 PM
rob6773 rob6773 is offline
I did mine two weeks ago and I got confused also. Those hangers attach to exhaust clamps. The clamp goes behind the muffler to connect the mufflers w/the tailpipes. The same clamps also go through those hangers that are pictured above. You may need to pick up extra clamps if you are not welding the system together. Go to the Pypes part of the site and look for their pictures, that really helped me.
Old 07-31-2004, 08:07 PM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
Actually, Shotgun is right, those hangers in the pics are incomplete. I just hung my tailpipes tonight from Pypes and had to reuse the little pieces from my old hangers. There is a little clamp crescent that bolts to those hangers with slots to move them side to side. These hangers, which are correct and just like the factory ones, are kind of useless without the other part.
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 08-01-2004, 08:05 AM
PY Staff -Tech
Mine was single exhaust stock,so I only have one.Know a source?I would rather"do it right". Yes I am type A.
Old 08-01-2004, 08:17 AM
quicksilver97ta's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by shotgun:
Mine was single exhaust stock,so I only have one.Know a source?I would rather"do it right". Yes I am type A. <HR></BLOCKQUOTE>
Use the bottom halve of a muffler clamp with two straight bolts (instead of the U-bolt) from the muffler hangers pictured above.
