Old 01-27-2023, 05:45 PM
67428HO 67428HO is offline
Default 1968 GTO quarter panel adhesive or foam?
Hello, What do you use on the sail panel of a 68 GTO when replacing the quarter? The factory had foam or some kind of adhesive that helped secure the quarter to the under structure at the sail panel area. Thanks!
67428HO
Old 01-28-2023, 10:53 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
Sem makes a flexible urethane foam used for body braces. It works well and is minimal expansion so it wont warp your panel. You will need a applicator gun for it though as its a dual cartridge.
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 01-29-2023, 07:56 PM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
That is a non expanding foam for vibration isolation so the middle of the panel has support and wont vibrate. You should be able to put the QP on then you can glue a piece of open cell foam at the right thickness between the inner mount and the QP. there should be enough room to get your arm in there to do it. use 3M seam sealer in the white tube. save you some money and aggravation.
Temporary mount the QP and see if there is room. Should be.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
Old 02-02-2023, 09:22 PM
Thanks!
67428HO
Old 02-04-2023, 12:05 PM
mrennie's Avatar
mrennie mrennie is offline
3M 04274 NVH foam.
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
