Flexplate differences
I need to buy a flexplate for a 400 crank. How do I know which one? There is an earlier one and a later one. The hole in the middle is bigger? What year was the change or what casting numbers?
Measure the crank register for the hole in the middle . Will be 2.5 or 2.75.
Then there are "internal balance" if a shop did it possibly or the factory "external balance" that has one hole missing.
I have a brand new on
In the box,yours for shipping cost.PM me.Tom |
The Following User Says Thank You to tom s For This Useful Post: | ||
Also early ones only have 3 converter holes. Later ones have 6 holes. Early torque converters have mounting hole farther out from the center. The ones with 6 holes will fit everything though later converters had metric bolts and the holes will have to be enlarged slightly.
The Following User Says Thank You to Kenth For This Useful Post: | ||
I found out about this the wrong way while doing a 400 install on a friends car. Of course we had the wrong flexplate and had to rush ship another one to finish the job except I had to fly home and couldn't stick around for the first drive.
