Old 11-17-2019, 09:12 PM
chiphead's Avatar
chiphead chiphead is offline
Default 67 LeMans pass fender repair?
Got the pass fender off the Lemans the other day. The upper rear mounting ear is totally rusted off. The plan is to find a donor fender and splice in what I need, which I think is the inner brace and the fender flange in this area. See picture.
The car is a '67. Is a '66 fender the same in that area?
Name:	pass fend resize.jpg
Old 11-18-2019, 02:59 PM
400 4spd.'s Avatar
The same.
Old 11-20-2019, 01:36 PM
chiphead's Avatar
Thanks!
Can somebody measure the location of that mounting ear on the fender? I could fab a replacement if I could get measurements from the rear edge of the fender to the center of the hole in the ear. I also need to know how far the center of the hole is from the inner edge. That would give me X and Y dimensions for locating the mounting ear.
Old 11-20-2019, 04:13 PM
sts sts is offline
99.9% of the time, the other side is a reverse image. Also, it's a fairly easy fab job.
Old 11-20-2019, 10:13 PM
MUSLCAH MUSLCAH is offline
^^^^^^^^ what he said...
Old 11-22-2019, 12:28 AM
chiphead's Avatar
I didn't want to assume it was the same as the other side, as sometimes it's not. Are you guys confirming it's in the same location as the driver's side? I've got 2 drivers fenders I can measure.
Old 11-22-2019, 08:50 AM
400 4spd.'s Avatar
You're over-thinking this. It IS in the same location as the driver's side. Also keep this in mind, GM was not perfect when positioning parts before welding them together. If they were, we wouldn't have a need for fender shims on these cars. And if they were identical side to side, you would use the same number of shims on one side as you do the other, but that's rarely ever the case.
So if you discover after your repair that each side requires different shim thicknesses, don't sweat it. GM didn't.
Old 11-22-2019, 03:00 PM
Frank R's Avatar
Frank R Frank R is offline
I wouldn’t go off of measurements. I would install it and set my gaps the tack it in place.
Old 03-16-2020, 12:32 PM
chiphead's Avatar
Update... I'd like to thank 6d7gto for the section he cut out of a fender he had. I finished grafting it in early this month, primed it with epoxy and it came out great. I'll post pics when I have time.
