Old 10-30-2019, 12:32 PM
cnc's Avatar
cnc cnc is offline
Default Transmission help 2009 Buick Allure
So I just went to leave for lunch put the trans in drive went about 2 feet no more go....seems like I have reverse and it will kinda move in low...that's about all I had to time notice right now....
I have noticed sometimes it was kinda delayed going into d from reverse when pulling out of my driveway....
Any help or known issue with these trans is appreciated ....Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 10-30-2019, 12:49 PM
stevep's Avatar
stevep stevep is offline
If it has a 4T65E, which it will have if it's a 3.8, you probably have a broken low band as it is a common failure in those transmissions.
If you can get it to move by being easy on the throttle, you will probably find that once it shifts into 3rd, it feels fine.
Old 10-30-2019, 06:33 PM
cnc's Avatar
cnc cnc is offline
Hi Stevep
Here is what I found once I started to see what it was doing
R seems fine
D nothing
3 nothing
2 it will move the car but get a shuddering feeling if I try to get it going a little
1 feels about the same as 2nd...I get a shudder in it
Looks like I'll be pulling it and getting it rebuilt....ball park to have it rebuilt with the usual needs stuff for one of these...just curious..
