Old 01-20-2022, 06:36 PM
66pontiacgto 66pontiacgto is offline
Default brake booster
Im restoring 69 judge and need to get a new brake booster. where is the best place to get one that is most like the original?
Old 01-20-2022, 07:01 PM
694.1 694.1 is offline
How "top shelf" are you aiming for? Given all the cars out there with re-pops, clean used ones that are ripe for restoration should be fairly easy to find?
Nice problem to have
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 01-20-2022, 08:04 PM
roger1's Avatar
roger1 roger1 is offline
I bought a new one from Ames with the Delco-Moraine stamping on it.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
Old 01-20-2022, 08:15 PM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
Bought a repro, it didn’t last long. I won’t waste any money on one again.
https://www.brakeboosters.com/
Old 01-21-2022, 11:35 AM
da judge's Avatar
da judge da judge is offline
Yes, I wish there was a way to better preserve the finish. 15 years ago I bought a mint core from Steve Gregori. I sent it back for replating some years ago and it needs to be done again.
Old 01-21-2022, 12:42 PM
dataway's Avatar
dataway dataway is offline
Do you have the old one? Check if it has a Delco stamp on it .. many of the as delivered originals did not, I think most of the OEM parts counter replacements did.
I think most of the vendors get them from the same place. Lots of them installed and trouble free for many years.
Old 01-21-2022, 01:07 PM
DavesGTO's Avatar
My original had the delco remy but very light. Oct 69 Baltimore car
Old 01-21-2022, 04:23 PM
dataway's Avatar
Just pulled the original off my Arlington and it was plain .. only a 56K mile car too. Thread on it in the 68 forum ... seems random with/without. I went ahead and saved the $20 and replaced it with another no-stamp.
If you still have the original and the cup seal is good (between MC and booster), consider using the old one, the reproduction boosters use a different type (at least mine did) that doesn't seal the gap between the MC and booster ... it's just a rubber washer that goes down in the booster cavity. The OEM piece seems much more robust.
If you want really correct ... bear in mind they are date coded and have application codes in some cases.
Old 01-21-2022, 04:41 PM
DavesGTO's Avatar
On the tab at the top.
Old 01-21-2022, 07:34 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
I've used Steve Gregori in the past and have been satisfied with his products. Hopefully this is a smooth transition and continues as a quality service.
Old 01-22-2022, 08:22 AM
dataway's Avatar
Jeez, only $285 to restore an original ... seems very reasonable, I was expecting about $400. Might have to send my original out and use the repop in the meantime.
Old 01-22-2022, 08:31 AM
DavesGTO's Avatar
Depends on the condition of the booster you send in, the polishing out and removing pits will run the price up beyond that. You can get to $400 unless you send a nice one. $75 to engrave delco remy if you choose to do that. I’ve definitely seen rusty ones, that would be pricey, but worth it for someone wanting to keep the original.
Old 01-22-2022, 09:52 AM
da judge's Avatar
The reproduction cup seal is definitely not up to GM standards. The one in my Gregori booster did give away after years of use. It cracked around where it seals against the push rod. It's a part that isn't serviced at my local parts counter. I took one out of a heavily rusted spare booster my buddy had. That original 50-year-old GM seal was still soft and pliable and worked perfectly.
Old 01-23-2022, 08:05 PM
Thanks for all the information. i am gonna send out original to get redone. just have to decide where to send it have found a few places that do it.
Old 01-23-2022, 08:18 PM
roger1's Avatar
What is this cup seal look like? Can you post any photos?
Old 01-25-2022, 10:33 PM
Andretti's Avatar
Andretti Andretti is offline
Had my contact information on a list with InlineTube as their '69 Booster/Master was sold out. They contacted me last week saying it's now in stock.
Name:	Screenshot 2022-01-25 213149.jpg
Old 01-27-2022, 05:59 PM
nashcar nashcar is offline
Had one done by brakeboosters.com, formerly Steve Gregori. The new owner was great and did a nice job. Mine was pitted and he removed it for an extra charge. Very pleased and quick turnaround.
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
Old 02-02-2022, 03:50 PM
DavesGTO's Avatar
Just got this back from Brakeboosters
