PS the E-heads have LS heart shape chamber.
The Following User Says Thank You to Gach For This Useful Post: | ||
Stan when I built my 455 with RAIV heads 1988 -hard to find before any Eheads etc were available UD 288/296 HFT on a 108 HO intake 73 SD Q jet it made about 420 HP on my machinists old conservative dyno. He built a guy a similar 455 but used some ported 6X heads and it was off the RAIV motor by about 50 HP also.
The Following User Says Thank You to Skip Fix For This Useful Post: | ||
Performer rpm I think that’s what it called.
If they where stock RA4 heads then the peak intake flow was 225 @ 28”.
Note that a stock Edelbrock performer will not make more then 420 hp. On a 406 cid motor with stock high comp D port heads and the RA4 cam and 1.5 rockers peak hp will be no more then 5600 . Bolt one on to a 455 set up the same way and your peak hp is now 4900 rpm.
I do stuff for reasons. |
Dyno sheet or pic or video?
Are you requesting that from myself or Gash?
Gach, That 502 HP @ 4900 is fantastic. Great combo! What Octane for ping-free Street use?
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
I recognize those numbers. It sure looks like the engine Built by Nick’s garage and dyno’d on their youtube channel. 66 heads should have been the big chamber 114 cc heads in 71, not 96. I have never heard of that big of chamber on 96s, that is pretty bizarre. Nick said the compression was mid 9s back when the dyno episode posted. He missed pretty badly on that if that is correct and I am correct on this engine’s past. Nice job Gach! |
The Following User Says Thank You to Jay S For This Useful Post: | ||
Stan
wouldn't a 702 installed @ 110 ICL with 11:1 CR crank over 200 psi? Stan
If you and I are looking at the same engine Nick did. I believe he got 395.7 peak HP. Stan
Gach,
So it made peak HP of 450 @ 4900? At what RPM was the 515 peak torque? Stan
It could just be coincidences, if it is they are for sure weird coincidences. I remember for the 455 Nick tested had 96 heads, but had RA manifolds and not 3 tubes. The cam swap went from the 702 Lunati to the 6014 Butler, which is the same, and the power was 370 something with the 702 and the Bulter cam was what Dyno results that you posted Stan.
Without looking at the numbers that close I think both cams would pump 200 ish at 11:1. Bulter cam might be 10 lbs less at most. The Bulter cam is more or less a XE274 widened out to a 112 LSA. The way it is ground with it’s very fast opening on the intake it doesn’t scavenge all that well on 112, between that and the later intake closing widening LCA out (creating the later intake closing) it can run a good amount of compression, 11 is pushing it though. I agree with Gach, I think the 60919 would have done better, especially with bigger ratio rockers. I am not really a fan of Bulter’s 6014 cam. Last edited by Jay S; 07-02-2022 at 11:17 AM. |
#38
Butlers cam made good numbers, to me there would be no question the 60311 would make bigger HP numbers, probably at the expense of low end tq though. What Crower sells right now as the 60919 is not a copy of a 041, it has less seat timing and the LSA is narrower. At least it isn’t the same anymore, it may have been the same many years ago. Last edited by Jay S; 07-02-2022 at 12:12 PM. |
#40
No.. heads are definitely 96, Clearly a 9-6 on center exhaust port, I used them before and think they were 96 cc chamber, I was told 114 cc that’s why I thought it was bizarre and reason why I checked them, come to find out he had chamber reworked in fear of having donation. Who ever did chamber work did a good job.
LOL we didn’t do a photo shoot. It was obvious to me, when I talked him into going with new Edelbrocks with LS heart shape chamber, that picking up 2-3 points compression and 60-70 more cfm head flow that it would definitely make more then 377 hp it’s a no Brainer. Ok speaking of 60919, and reason I prefer it over comp cam, there’s another build I was involved with. And this is all documented, cleary a video of him running 11.60’s at Norwalk. It’s 67 GTO that weighs 3600 lbs. it’s a 400 block 040 over. with crank I sold him, cast 455 crank done by crankshaft specialist, anyway works out to 461 ci. Out box Edelbrock heads, not heart chamber ones. Performer rpm intake and a Q’jet done by Cliff R. It has switch pitch convertor has a switch he flips. Believe it works out to 3500-3800 stall. All on pump gas. Cams in at 108, if you account for timing chain stretch it ends up 110. One other thing their round port e-heads Fact he has a block of wood under gas pedal to keep it from going faster then 11.60’s has no roll bar in the car. It doesn’t want to put one in. So figured it out 3600 lb car 11.60’s how much hp.
