#61
Stan
#62
check out the june 2013 car craft. almost your exact combo. 577tq./464 hp. 234/242 fth.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
The Following User Says Thank You to KEN CROCIE For This Useful Post: | ||
#63
Stan who cares !
I remember that article think I still have it.
Horsepower = Torque x RPM / 5,252
The Following User Says Thank You to Steve C. For This Useful Post: | ||
#66
150 CFM @10" on the intake exhaust was 85% of intake.
The Following User Says Thank You to Skip Fix For This Useful Post: | ||
#67
For the sake of something we can all reference and kinda have a known base line let’s use this.
In sept 2002 issue of HPP they did a octane test on a 467 with 9 to 1 comp, Dave’s ported 6X heads ( 250 cfm) a hydro Comp cams roller and a TII intake and a 750 Holley. The best Hp this motor made while on 88 octane was 488.6 at 5100, peak Tq was 551@4300. The motor did go on to make 493 hp at 5200 and 549@3500. This was when being fed 100 octane. At 493 hp the motor was only using 239 cfm per cyl for those who may be interested.
I do stuff for reasons. Last edited by 25stevem; 07-02-2022 at 08:12 PM. |
The Following User Says Thank You to 25stevem For This Useful Post: | ||
#68
Do you have a link to the article? I would interested to see if they did anything other than just change octane since peak torque happened 800 RPM earlier. Stan
#69
Good that someone worked over the 96 heads that Cc’d at 114 and they didn’t come from PMD that way in someone’s would be 7:1 SCR 400 in their 71 GTO or FIREBIRD Would have been a runner. LOL
When I first read the similarities I thought maybe Nick’s client was back hunting more power and the project was back up on their YouTube channel Be fun to see how the ported 96 heads I have would compare to those E’s and against stock 96s. They are bolt on top a 10:1 455 with a comp SFT cam, waiting to go in a 71 T37. Last edited by Jay S; 07-03-2022 at 12:27 AM. |
The Following User Says Thank You to Jay S For This Useful Post: | ||
#70
Originally he plan to go twin turbo, reason why he had 96# chambers open up to bring compression down. once he found out all the fabricating involved. Welding equipment he would have to purchase. Plus The immense learning curve and all the Contradictive information out there, he gave up. All he wants is a nice street cruiser.
Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
#72
Can we see a pic of the chambers? Be interesting to see how SD removed almost 20cc from the chambers.
#73
Personally I feel someone along the line needed a new project manager. A lot of time, money and effort involved in shipping a pair of heads to Canada, having $800 worth of work done to the chambers and returning a stock port head back to the customer. 114 CC iron heads are readily available for between free and fifty bucks and come with induction hardened valve seats. SMH Nick would've probably been happy to sell his for $200 (ready to bolt on) after achieving the same results. |
The Following User Says Thank You to PAUL K For This Useful Post: | ||
#75
I'm glad to see good Iron head performance.
Oh sure I'm aware of bolt-on aluminum head offerings, but i just got to share the project goals of most are to wring out the Iron head combos for a certain satisfaction, along with keeping resilience in Winter, Summer, and oh-schlits situations like an overheat. Still own 2-sets of heads (RA IIs and IIIs) which have received careful modifications internally across decades to keep them snuff. The HP level is not where my former Iron heads have been butt hay if there is a clear indication of where to modify my combo for HP, then off we go! This Thread has emphasized cam and compression, and some heads-manship, but maybe i'm missing something but seen no valuable info to glean, as to what change i need to perform to replicate a claimed result. Go!
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
The Following User Says Thank You to Half-Inch Stud For This Useful Post: | ||
#76
Naw, i either had the goods, got the goods, or know what goods i need. The matter is to know what Iron head mods along with manifold/mods make improvement. For sitting at 12.0 ET on 89 Octance, and <\= 5100 rpm, the desired additional mods are rare to know.
#79
Stan, I am trying to find the HPP issue where the motor was first built.
Hey Rocky can you help ?
I do stuff for reasons. |
#80
Here is another "nice low compression street engine". It was topped with #96 iron heads ported to 250cfm, 9.3 to 1 compression and dyno'd with two different camshafts, no other changes. It used a port matched RPM intake and late 70's Pontiac Q-jet.
The Following 3 Users Say Thank You to Cliff R For This Useful Post: | ||
