Old 02-02-2023, 12:35 PM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
Default 1969 T/A Code 11 code Paint
My local Auto paint store wants a Dupont code and cant use the GM #11 or the PPG #WA3967. Can someone provide the Dupont paint code for this white #11? Thanks again.
1970 T/A
Old 02-02-2023, 01:11 PM
Rob in NH's Avatar
Rob in NH Rob in NH is offline
I'm looking at my 69 Dupont book and the only white for Pontiac is paint code 50, cameo white and the formula is 5033.
Old 02-02-2023, 01:14 PM
Rob in NH's Avatar
I just looked and found it in the 70 chips, same formula 5033. Just found another in 71 chips code 11 and that formula is 5338
Old 02-03-2023, 02:30 PM
dpoltzer's Avatar
Default tyrol blue code too?
Thank so much Rob. I also should have asked for the code for the Tyrol blue for the 1969 T/A as well? Thanks again.
1970 T/A
Old 02-03-2023, 03:32 PM
Rob in NH's Avatar
Could you get me the paint code ? Then I should be able to get the formula number.
Old 02-03-2023, 07:18 PM
Rob in NH's Avatar
what I found here was that tyrol blue is a 67 color, paint code F, formula # 4850 or it could be a 69 GM lemans blue code 71, Formula# 5030.
Old 02-03-2023, 09:22 PM
dpoltzer's Avatar
Default 4850 is a Metalic?
Thanks again Rob. It looks like Tyrol blue is a metalic color. I am painting the T/A Cameo white in a single stage Urethane. Do you know if Tyrol Blue comes in a single stage Urethane or will I have to spray the T/A stripes and rear tail panel in a base coat clear coat? Also, if I have to spray the blue in BC/CC, will that paint be compatible to spray over the single stage Urethane when doing the stripes? Thanks again. Dave
1970 T/A
Old 02-03-2023, 09:35 PM
I'm pretty sure that you can get single stage metallic. Those TCP Global people have everything, but you'll likely find someone local.
Old 02-03-2023, 09:50 PM
Rob in NH's Avatar
Yes those can be made in single stage.
Old 02-04-2023, 07:25 PM
dpoltzer's Avatar
Default Many Thanks.
That is good news on the single stage Tyrol blue being available. I will call paint store Monday. Thanks again. Dave
1970 T/A
