Old 10-20-2018, 12:32 PM
pggto's Avatar
pggto pggto is offline
Default Correct Fan
I'm replacing the aftermarket flex fan on my 70 with a clutch fan I have. Just curious if this is the correct fan for 70. The part number on the blades is 498579. My car is non AC, I still have the original fan, but was always under the impression that clutch fans were a nice up grade? Any truth to that? Thanks
ID:	495532   Click image for larger version
Old 10-20-2018, 01:52 PM
Non AC '70 GTO should have 5 blade factory flex fan. Factory AC, then engine receieved the std clutch controlled fan. Typically, the correct stock 7 blade clutch fan will cool better than the same model factory five blade flex fan. Have experienced this on two no AC 4spd cars, one a '70 GTO with 3.55 rear gear, the other a 4spd 78 T/A with 3.42's. Both had modest upgraded 400's.
Old 10-20-2018, 03:26 PM
Forrest's Avatar
Forrest Forrest is offline
^^^^ THAT!...Tried a flex fan on my '70 455 (.30 OVER) 4 spd. modified GTO (around 510HP..) used it for about a week..went with a 7 blade factory clutch fan and had much better cooling..and ALOT quieter!
Old 11-01-2018, 12:28 PM
I always wondered if you ordered the clutch fan on a non A/C car did you get the AC pulleys (water pump and crank) or the regular pulleys. The difference is that the AC cars have pulleys designed to spin the water pump (and the fan) faster.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 11-01-2018, 04:29 PM
Held for Ransom's Avatar
My '70 455 was ordered with the '6134 clutch fan (non-AC) and came with the XF fan, XD power steering and YA crank pulleys.
So long, farewell.
Old 10-31-2020, 05:49 AM
Jimbobeast Jimbobeast is offline
Which fan was correct for a '70 RA IV MT car (no AC obviously)? I believe it should be a direct drive (no clutch) 5-blade flex fan. If so, what size spacer was correct?
