Old 11-26-2020, 11:28 PM
mrennie's Avatar
mrennie mrennie is offline
Default 70 cruise control lever on Oshawa GTO's??
Hello,
My Judge was a basket case when I bought it many years ago, and I ended up buying another 70 GTO (Oshawa build) for parts that had only been on the road until 1974, due to being T-boned and parked, and never driven again.
The interior of the parts car was all intact and I am 100% sure it was factory original when I stripped it. That car was a 400/T400 with optional cruise, and I have noticed many times while looking at turn signal arms for cruise control that they look different than what was on this GTO.
I finally found out what the arm is from...a 1969 full size Olds.
Has anyone seen this before? Is this an Oshawa thing? Maybe there was a parts shortage when this car was built and they grabbed whatever they had?
First pic is GTO lever from Ames catalog, rest are the reproduction 69 Olds full size lever from eBay then pics of the arm on my 70 GTO steering column (button is missing).
Name:	GTO lever.jpg
ID:	554836   Click image for larger version
ID:	554837   Click image for larger version
Name:	olds arm 2.jpg
ID:	554838   Click image for larger version
ID:	554839   Click image for larger version
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Old 11-30-2020, 11:38 AM
Much more likely that it was simply changed out later in life.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 11-30-2020, 07:23 PM
mrennie's Avatar
I had considered that, but I bought it from the original owner and it was only on the road for 5 years before being wrecked and stored until I bought it. Seller said it was all original except for long block that was changed under warranty when he blew the engine.
Michael
Old 12-01-2020, 07:38 AM
Oshawa built 1 option Judge that was a real basket case,
Is the cruise on this Judge?
Old 12-01-2020, 08:58 AM
mrennie's Avatar
No, the one option (besides the Judge package) was white strip tires.
The parts car GTO that I bought also had very few options, basically tinted glass, console/buckets, AM radio, clock, and cruise.
Michael
Old 12-01-2020, 11:31 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
If the car had any issues under warranty it could have been swapped out without much notice. Or the car was built with cruise but in final checkout it was noticed that the wrong steering column was put in due to a mixup (I presume it would either be repaired at the end of the line or shipped to the dealer with a note for them to fix it).
A full size Olds turn signal being put in a mid sized column seems odd from the factory, did they build full size Olds on that factory line in those years?
Old 12-01-2020, 02:10 PM
mrennie's Avatar
I'm not sure what other cars were built at Oshawa..and looking into the cruise lever some more, some Olds sites also list it as fitting a 70 Cutlass which makes it seem more possible to get into a GTO.
Must not have been common (or not done at the factory) as I would have expected someone else to chime in that they had seen this before.
Michael
Old 12-06-2020, 01:54 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
There's a dilapidated 70 GTO within 10 miles from me with a aftermarket cruise control set-up. I've tried buying the car for years. The owner dad bought the car for him after returning from Vietnam. IIRC he said the cruise control set-up was purchased from Sears and Roebuck.
