Old 02-19-2008, 09:10 PM
RAIV55 RAIV55 is offline
Default '02 Silverado TS switch replacement
I just bought a service manual on CD. Long story short it didn't load or work in my computer. I need information on proceedure for turn signal switch replacement.
Thanks!
Old 02-19-2008, 10:36 PM
goatnut's Avatar
goatnut goatnut is offline
On most newer GM vehicles just remove steering column covers to gain access to switch remove usaully 2 or 3 screws and unplug. I will check the manual [on shop pc]tomarrow and get back to you with more accurate details.
69 GTO Judge
69 Firebird Trans Am clone
76 Trans Am 400 4spd.
06 GTO M6 18's red/red - 1 OF 188.
09.5 G8 GT Stryker blue met. premium with sport pkg.
Old 02-20-2008, 09:45 AM
goatnut's Avatar
Default Multifunction switch replacement - on vehicle
Here it is step #1 disable the SIR system - air bag
2 remove knee bolster
3 loosen steering column bracket nuts
4 remove the steering column trim covers
5 disconnect the steering column bulkhead connector from the vehicle harness
6 disconnect the gray and the black connectors [2] of the switch from the column bulkhead connector
7 disconnect the automatic transmission shift lock control electrical connector
8 remove the wire harness straps from the steering column wire harness [1]
9 disconnect the park position switch electrical connection
10 remove the multifunction switch retaining screws from the switch
11 remove the multifuntion turn signal/hazard switch.
To install reverse procedure.
Hope this helps you.
Rob.
69 GTO Judge
Old 02-21-2008, 01:48 AM
Thanks a bunch goatnut! I was dreading the job, but don't sound too bad from your instructions.
