Old 07-29-2009, 01:31 PM
Mo's Avatar
Mo Mo is offline
Default "ScanningProcess.exe" What is it?
It seems like my PC is always scanning. I have an 02' gateway with XP and use mozilla, Verizon internet and Verizon security. I just used spybot S+D, and CC and it is still doing this "scanning". My security is programmed to scan at night so I don't think it has anything to do with that. My online searches to this problem(if it is a problem) were not helpful. Any ideas? Thanks
Systems under stress fail catastrophically
Old 07-29-2009, 02:16 PM
TA455HO's Avatar
TA455HO TA455HO is offline
If I Google the scanningprocess.exe I get tons of hits. Sounds like it comes from Zone Alarm software.
http://lmgtfy.com/?q=scanningprocess.exe
Old 07-29-2009, 03:38 PM
Mo's Avatar
Mo Mo is offline
I've read several of the posts and can't tell weather it is a problem. Some say it is part of Verizon security as long as there is only one. Some say it is from "Zone Alarm" and that it should be removed. I never added "zone alarm" as far as I know. If it was a problem wouldn't spybot and cr*p cleaner know that? I have some of the same "slowness" issues that others posted but it is only really bad at start-up.
Old 07-29-2009, 06:38 PM
TA455HO's Avatar
If you search your local hard drive(s) for ScanningProcess.exe and it locates the file you should be able to determine what folder it is in. That might remind you how it got installed. Or maybe not. Generally it is running when it is scanning for viruses, but if it never stops using CPU time then that might be an indication that something is wrong. I don't know enough about that software to know, but Norton runs things like RTVScan.exe on occasion and it can suck up a bit of CPU while it is actively running. But, once it is done then it calms down a bit and doesn't seem overly intrusive.
Old 07-29-2009, 07:48 PM
Mo's Avatar
Mo Mo is offline
Looks like it is part of Verizon security. It is a "Kaspersky" deal. According to the date, it was installed when I switched to Fios. Thanks, and nice T/A in the avatar
Old 07-29-2009, 10:38 PM
tripower's Avatar
tripower tripower is offline
If it's bogging down your puter, you might want to try and uninstall it and switch over to something like Symantec, which only runs at bootup.
Norm J
