Old 11-09-2010, 08:38 AM
chiphead's Avatar
chiphead chiphead is offline
Default '04 Silverado valve clatter?
Now that it's cold, the 5.3L in my 04 Silverado is clattering to beat the band when I start it in the morning. It continues to clatter until I drive it a mile or two. Oil pressure is good, 5W30 oil, runs fine, 121K miles. I bought it new and it's been maintained. It sounds like valve clatter, and it's LOUD.
Any insight? Thanks!
Old 11-09-2010, 08:52 AM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
It's probably piston slap. Lots of history there with the LS truck motors. As long as oil consumption doesn't go up dramatically, get used to it.
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
Old 11-09-2010, 08:54 AM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
Piston slap..... unfortunatly .... normal. Mine has been doing it since new.... 160,000 miles later.... no better .... no worse.
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
Old 11-09-2010, 11:04 AM
sleepy's Avatar
sleepy sleepy is offline
My 5.3 didn't have that.(traded at 110,000) I used Moble 1 sence new and a can of seafom every other tank,
Why is he not suspended?
Old 11-09-2010, 11:28 AM
Larry P's Avatar
Larry P Larry P is offline
A lot of 5.3s do this, not a concern really, my 2000 Tahoe 235,000 miles done it since day one. GM released a statement they would cover the engine for 100k when it first started.
Old 11-09-2010, 11:40 AM
69goatboy's Avatar
69goatboy 69goatboy is offline
My 99 F-150 (4.6) just started doing this. Oil consumption is about a quart a month. Goes away after a few miles.
The joker in the deck keeps sending me his card.
Smiling friendly, he takes me in.
Then breaks my back in a game I can't win.
Old 11-09-2010, 11:59 AM
67drake's Avatar
67drake 67drake is online now
Not at all uncommon. I owned one of these new generation engines a 6.0 in my 99' 2500 Silverado,and I think more people HAD this problem than ones that didn't. It is so common that they stickey'ed it on my truck site.
http://www.fullsizechevy.com/showthr...ine-Knock-Info
Note that this thread was started about 8 years ago!
You can read for hours on this subject.
13.95 @ 102.1 on street tires @ 4055lbs.
Old 11-09-2010, 01:04 PM
SRR's Avatar
SRR SRR is offline
Are you running a "bargain" oil filter? Some filters have check valves to prevent drain back. I run a Mobil 1 on my Dakota and since then I have NO start up noises. It's worth a try. The shops I deliver parts to swear by that Seafoam product also.
― Calvin Coolidge
Old 11-09-2010, 01:11 PM
quicksilver97ta's Avatar
Same here, 99 gmc. As the mornings get colder I get in the habit of letting it warm up just a minute, maybe two, and I usually dont hear it.
Old 11-22-2010, 10:53 PM
chiphead's Avatar
Update: I changed the oil and the clattering went away completely. I guess she'll let me know when it's time for an oil change....
Old 12-07-2010, 08:16 AM
chiphead's Avatar
Now everytime it sits for a few hours, it gives a big puff of blue smoke on startup. It just started doing this after the valveclatter episode. 125K miles on truck. I changed the oil twice recently hoping it was overfilled or bad oil. Is this related to the clattering or just normal wear? Runs fine otherwise but the smoke looks ghetto.
5.3L gas engine. Is this typical? What could I check?
Old 12-07-2010, 05:34 PM
mrrat1 mrrat1 is offline
I noticed my SS started to do this in the summer. It goes away by the end of the block. Think I will try the "seafoam" which I have never heard of! So what is this stuff, like a zinc additive. Thanks Dave K.
Old 12-07-2010, 06:52 PM
Cammer-6 Cammer-6 is offline
seafoam is nothing more than a solvent
bad for bearings
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 12-07-2010, 09:44 PM
Brian Baker's Avatar
The 5.3 in my 99 GMC does the same thing...but it sounds like it's one lifter and not piston slap, and only does it when it is cold outside during cold start ups. It started doing it when my father still owned the truck and it had less than 50K miles on it. It always goes away after 1 minute though, once the oil gets flowing good. It has 158K miles on it now, and started using oil around 125K miles. It goes through 1 to 1.5 quarts of oil every 3K miles. I'm sure it's burning it but I can find no evidence of it on the plugs or out the tailpipe. I'm not worried about it, I'll just keep driving it until it quits.
