Old 04-20-2023, 04:33 PM
'69ragr's Avatar
'69ragr '69ragr is offline
Default 1964 Tempest Drag Racing Car For Sale
CHASSIS: 2620 Lbs. with motor, no driver, have title
-square tube chassis/aluminum interior 8:50 Certified, belts current
-Hoosier fronts & rear (25 passes), Weld wheels
-Global West upper & lower control arms, Moser 12 bolt, 40 spline axles
-QA1 front SA coil over, Koni SA rear, Wilwood brakes & master
-Glass front, doors, rear lid. Lexan side windows
-Racepak Sportsman/ USM 4 port module, oil, gas, vacuum, driveshaft, RPM
-Innovate LC-2 A/F
-MSD 7531 Digital 7, crank trigger
-Speedwire complete electrical system & control panel
-Dedenbear Delay Box, Precision Performance Shift with CO2 shift
-Pontic front plate, T400 dual pattern mid plate
-Killer Racing T400, rev manual, Ultra-Bell, SFI Blanket, Mallory 250 pump
-Neal Chance bolt together 5500 stall converter
MOTOR: 539 IA2 Iron block (machined/prepped/assembled Forest&Forest Racing 727 HP on chassis Dyno) 10 passes on motor, 9.40 ¼, 6.0 1/8, not dialed in
-new Molnar forged 4.5 crank, forged 6.8 rods, Ross pistons 13.5 compression
-LSM Cam 304/282 dur. ,809/.776 lift
-ported Victor, 1050 Shaker Tuned Dominator
-SD Performance 350 CFM heads, PAC springs, 1.65 Crower Shaft Rockers
-MSD Distributer, Stainless 1 7/8” headers, Meziere water pump/ alum rad, Powermaster race alternator
-Star Vacuum Pump and catch can, Accusump (not installed), engine Diaper.
Will e mail pictures if I can't figure how to post.
Asking $28,000.00 or best reasonable offer. Located in Guelph, Ontario Canada.
Deno/'69 ragr
'64 Tempest pump gas 535ci.
Best time 9.61 @139mph, 1.32 60'
Old 04-21-2023, 08:08 AM
'69ragr's Avatar
The '64 is also listed on Racing Junk , click on link to see pictures
https://www.racingjunk.com/complete-...9-cu.inch.html
Deno/'69 ragr
Old 04-21-2023, 12:27 PM
JacintasHot's Avatar
JacintasHot JacintasHot is offline
That's a nice car.
Hecho en China is not good for U.S.
Old 04-24-2023, 08:51 AM
'69ragr's Avatar
Price $26,000.00 and will include new (dyno only) 1200 CFM Dominator built for this motor by Patrick at Pro Systems.
Deno/'69 ragr
Old 04-24-2023, 08:15 PM
PontiacFan428 PontiacFan428 is offline
Is that in US dollars or Canadian dollars?
Old 04-25-2023, 02:22 PM
'69ragr's Avatar
Thant is in US dollars.
Deno/'69 ragr
Old 04-28-2023, 02:32 PM
'69ragr's Avatar
New Price $24,000.00
Deno/'69 ragr
Old 05-15-2023, 10:12 AM
'69ragr's Avatar
$23,000.00 will include from previous builds 2 solid roller cams with matching springs, push rods, 1.65 Scorpion rockers, 1,65 PRW rockers, rocker stud girdle, 4150 ported Victor, Torker intake, plus misc. Pontiac parts.
Deno/'69 ragr
Old 07-23-2023, 06:45 PM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Still for sale?
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 07-24-2023, 08:16 AM
'69ragr's Avatar
Sold, thanks
Deno/'69 ragr
