I have a 71 Trans Am basket case,and noticed it has what looks like the thick hear adams sway bars front and back.Is this factory or no?If not,what belongs there?Thanks
I believe the 70-73 TA's used a 7/8" rear sway bar and a 1 1/4" front right from the factory. They changed them throughout the ears of the 2nd Gen F body and with the different models. The Formula of those years I believe had a 1 1/8" front bar, and the base firebird something even smaller.
------------------ Wade Congdon - BOP Engineering www.bopengineering.com "If you can turn left you're going too slow"
Wade Congdon BOP Engineering Hi-Performance Specialty Parts for Buick, Olds, and Pontiac www.bopengineering.com |
According to my copy of the '71 Pontiac Press release (which was included in my Pontiac Historic Services folder) the Trans Am had a 1-1/4" front bar and 7/8" rear. The Formula had 1-1/8 & 7/8.
DanC
------------------------------ 1968 Firebird Convertable - my original HS car! 1978 Firebird Esprit "survior" 1930 Ford Model A Coupe .. (original) 1994 Buick .."TowMaster" ...woody wagon |
The Adams front & rear bars were 1 5/16" & 1" respectively. The front Adams bars attached via small brass or steel mtg blocks bolted to the lower control arm with Heim jointed links between these blocks & the swaybar ends.
If your front bar is connected via the std bolt-sleeve-bushing routine, chances are you have the '70.5-74 T/A front bar.
