Old 11-19-2020, 11:10 AM
57Chief 57Chief is offline
Default 57 - Exhaust manifolds 455
Looking to see if someone here has put a later model Pontiac motor in a 57 Pontiac? My main question is has anybody used long branch manifolds from RARE in this application and did you have any problems clearing steering box? Any responses are welcome even if you used other manifolds but Im really wanting to use 2.5.
Old 11-19-2020, 07:21 PM
694.1 694.1 is offline
I have long wondered if a right manifold would be the ticket for the left side? Let us know
"At no time did we exceed 175 mph.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 11-19-2020, 09:20 PM
I installed a 400 in my 1957 Chieftain using factory manifolds but NOT ram air/HO manifolds.
Old 11-20-2020, 02:52 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
From installing RARE long branch manifolds in my GMC (with '55 HydraMatic case)- I'm guessing the long branch manifold outlets will collide with the rear engine mounts. I had to remove the GMC crossmember and build a custom crossmember and engine mounts, which is now a very crowded area. The driver's side is even more crowded.
Old 11-20-2020, 02:56 AM
Originally Posted by 694.1 View Post
... a right manifold would be the ticket for the left side?...
Umm... with the outlet aimed up at the firewall, or aimed forward?
Old 11-24-2020, 11:07 AM
Thanks for all replies. Still hoping someone will respond who as actually done exhaust manifolds on a 57 with later model motor.
Old 11-24-2020, 11:32 AM
"Umm... with the outlet aimed up at the firewall, or aimed forward?"
Well, I have an extra right side head...I just need to work out the water cross over from the left rear to the right front...
7th Firebird
57 Starchief
Cold Case Radiators
Cold Case Radiators is a Max Performance company that produces high end aluminum performance radiators at a price point that won't break the bank. Polished and stamped tanks. 2 rows of 1" tubes. Lifetime Warranty.
GTOG8TA.com
GTOG8TA.com is a Max Performance company that manufacturers parts for the 04-06 GTO, 08-09 G8, and 93-02 Firebird/Trans Am platforms.
