Old 05-30-2020, 08:04 AM
Jay S's Avatar
Jay S Jay S is offline
Nick wasnít your build more of a road course type build rather than 1/4 mile?
Old 05-30-2020, 10:17 AM
Jay S's Avatar
They arenít talking 238/238 with a SOLID roller are they? Is that a Hyd roller. First post said solid roller.
238/238 in a solid roller by the time the lash was factored in would be a small cam.
Old 05-30-2020, 11:53 AM
AIR RAM AIR RAM is offline
Originally Posted by Jay S View Post
Nick wasn’t your build more of a road course type build rather than 1/4 mile?
Yeah, I kind of want the best of both worlds. Leaning on road coursing as far as cooling, breaking and suspension set up. But want as much power as possible yet still be able to keep it cool in Miami heat traffic.
Once the set up can reliably perform locally I plan to start participating in the Power Tour and Drag week as well as other long performance car drives.
They aren’t talking 238/238 with a SOLID roller are they? Is that a Hyd roller. First post said solid roller.
No., I was initially wanting a solid however , Since I plan to do a lot of street driving I changed my mind in favor of a Hyd Roller.
NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 06-14-2020, 06:33 PM
I have a custom Comp Cams HR camshaft that I purchased several years ago from a forum member. I am almost leaning on running this cam on my build... Not sure what to expect with it.
These are the specs of the cam I have... not sure if I should sell it or run it... looking for opinions... I had to peace the specs together based on the comp grind numbers and info the seller provided to me...
Comp cam hydraulic roller.
Part# is 51-000-9 the grind# p 3315/3112
Valve lift Intake / Exhaust with 1.5: .510
Duration: I 281 /E 290
Lobe sep: 110
Valve timing @ .050
Intake Opens: 5 btdc Closes: 45 abdc
Exhaust Opens: 44 bbdc Closes: 4 atdc.
Lobe lift
Intake: .3400
Exhaust: .3400
Run it or sell it?
SPEED SAFE, NICK
Old 06-15-2020, 09:42 PM
ErikW's Avatar
ErikW ErikW is offline
I do know that the larger cid motors like more LSA and subsequently so do turbo motors so I would ditch what you have in favor of a more turbo oriented cam. I chose to go with a custom Bullet grind from Herb at Luhn Performance. It has an LS firing order and 116 LSA
1964 GTO
9.76 @ 137mph
1971 Trans Am Lucy Blue, 11.65 @ 115
2009 G8 GT
Old 06-16-2020, 10:04 AM
Thanks for your input... I was already leaning that way. And is why I really never brought up this camshaft in previous post... I was just hoping to hear someone say... ďI ran a cam like that and it did greatĒ ... but I already had a feeling it was not a good cam for this setup.
Iíll be going with a custom cam... you brought up another great name to consider going to for cam recommendation.
I guess itís time to put this roller up for sale as I doubt Iíll ever run it... lol
Old 06-16-2020, 12:08 PM
bad69bird's Avatar
bad69bird bad69bird is offline
IMO, Call Uncle Tony @ BES and get him to spec you out a cam or stay with Bullet. I prefer to stay in my lane and let the professionals handle it. lol
Good Luck!!!
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
Old 11-19-2020, 12:35 AM
David Holmberg's Avatar
Drag Radial
Good Luck!!!
Agree, but will include Lee, the man really understands valve timing.
The Following User Says Thank You to David Holmberg For This Useful Post:
Old 11-20-2020, 04:37 PM
I appreciate all the responses.
I ended up leaning on Herb at Luhn Performance for Cam and oil control tasks.
Herb is a great guy to deal with who is not only knowledgeable with building high HP (Boosted) Pontiac engines, he is more than willing to take the time to speak to you and answer questions. Something I have found not to be so with many of the other big names in the Pontiac community who give off a more of a feeling of being part pimps.
Luhn also has an many great products that are not even listed on their website. You would never know about these products unless you spoke with them or know someone who has mentioned them.
I also picked up their LPI "Pacemaker" TV-1S Oil Pump, Three Point Oiling Grooved Cam Bearings and plan to run their EFI Cam synch set up with a 58T tone ring.
For those who are not familiar with Luhn Performance, I suggest you at least get to know them and learn how they can help you with your performance Pontiac build.
SPEED SAFE, NICK
Old 11-20-2020, 05:19 PM
Herb from Luhn recommended that I run the same cam you have.... so thats what I went with... I will be running approximately 8.75:1 and about 10-15lbs boost... may tease the idea of E85 and 20lbs one day...
SPEED SAFE, NICK
Cold Case Radiators
Cold Case Radiators is a Max Performance company that produces high end aluminum performance radiators at a price point that won't break the bank. Polished and stamped tanks. 2 rows of 1" tubes. Lifetime Warranty.
GTOG8TA.com
GTOG8TA.com is a Max Performance company that manufacturers parts for the 04-06 GTO, 08-09 G8, and 93-02 Firebird/Trans Am platforms.
