#141
Yes it's on the sand core so it shows up there too. Lot's of gains to be made just cleaning things up and a performing a really good valve job. You can see how they barely port match the entry on the intake side. With very little work this could be blended further into the port.
We are going to put a set right out of the box with nothing more than a spring change on the dragster. Then after we baseline that, we'll just touch up what most people would as I mentioned above and hit it again.
Randy Repp 1964 GTO "GoatZilla" 1964 GTO "Injunuity" A/FX Nostalgia Super Stock 220" Rear Engine Pontiac Powered Dragster https://www.facebook.com/PontiacSpeedShop/ https://www.facebook.com/GoatZillaRacing/ https://www.facebook.com/groups/RebuildExcitement/ https://www.facebook.com/Call1844RacersRV/ https://www.facebook.com/groups/INJUNWARS/ |
#142
#143
Cool!
Thanks for the info.
#144
They outflow Eddys as cast and I believe with minimal effort Dave will have some good gains for a very reasonable price. Of course they've made improvements in manufacturing that save you $1200 a pair in price but it's only money.
#146
Randy, how long are the valves as compared to E heads and High Ports ?
#147
5.210 Intake 5.255 Exhaust.
#148
I did see one thing that looks like an inclusion, but otherwise they are looking good.
When people tell me they HAD to sell their car when they started a family, I show them the three car seats in the back of my 69Trans-Am..............and we didn't even use car seats back then!! |
#149
I was in a rush to let everyone see the sectioned pieces but I should have wiped them off first. Thanks.
#150
Did you figure out what the little core plug was for?
Possibly a clean out hole? The one towards the outside between the intake valves. Clay |
#151
Just another area to knock the core sand out of the castings. I'll be tapping these for a pipe plug just to be sure no water gets in the oil!
#152
Wouldn't have to worry about expansion rate or electrolysis of any kind. Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
#153
Absolutely.
#154
This one?
#155
#156
Valves ?
Why is the ex. valve longer? An old trick,to help with reversion,was to sink the ex. valve .Doing so required a shorter ex. valve or different length push rods.
#157
That is the specs they list. I haven't actually measured them yet.
#158
Feeling Dumb
But that hole is where a support leg came through to hold the sand core plugs exactly where they belong. To prevent core plug shift and thin spots. Makes for a more precise and repeatable casting, less defect castings. Same thing as freeze plug/core plug holes in factory heads and blocks. Clay Last edited by "QUICK-SILVER"; 05-17-2019 at 10:10 AM. |
#159
#160
A really good test for the quality of the castings will be to get some of these heads on street cars. Running them through many heat cycles, getting them up to 220-230 degrees F, then letting them cool. Cold starts and run right up to temp and then shut down. Then after many cycles, remove the heads and see how warped and twisted they are. I have no idea how they will do. The LS heads are very lightweight and have huge voids and large water jackets. I have machined the decks on two sets this week. One a set of 5.3's , the other 6.0L. All four heads looked pretty bad but the worst of the 4 cleaned-up very flat with .006" material removal. I hope these Pontiac heads are just as good. The LS heads were factory castings. They were warped in typical potato chip fashion, low in the middle.
