Old 09-21-2021, 04:51 PM
carbking's Avatar
carbking carbking is online now
Default Rochester 2G, 4G power valve tool
There was a comment in the tripower section about a slotted screwdriver to use with the Rochester power valves. This tool can be made by anyone with a screwdriver of the correct blade thickness and a hacksaw.
But, both Carter and Stromberg supplied a tool for their power valves (or the Carter multiple jet) that is much better for someone that works on carburetors more than occasionally. This tool may be made (or acquire one of the factory tools).
A word picture:
One starts with a piece of 7/16 inch steel rod about 6 inches in length, and a junk 3/8 drive socket
Chuck the rod into one's lathe and drill a hole in one end 3/4 inch deep using a number 42 drill (0.093) inch.
Now, remove the rod from the lathe, and using a mllling machine, remove 0.196 material from the both sides of the same end, leaving a "screwdriver" blade 0.040 wide, and 0.075 tall.
Cut the socket drive from the socket, and weld the opposite end of the rod to the socket drive.
Observe that when using the tool on a power valve, the power valve plunger will be inserted into the center hole, thus no force will be exerted on the plunger, thus no damage to the seat will occur.
Also observe the "screwdriver" blade has a straight "vertical" rather than the tapered "vertical" of a conventional screwdriver; thus the slot will not be damaged on power valves one tries to remove from carburetors that one salvaged from the bottom of a pond
And the old saying "a picture is worth a 1000 words"; here are three:
https://www.thecarburetorshop.com/Po...lve-tool_1.jpg
https://www.thecarburetorshop.com/Po...lve-tool_2.jpg
https://www.thecarburetorshop.com/Po...lve-tool_3.jpg
Jon
The Following 2 Users Say Thank You to carbking For This Useful Post:
Old 09-21-2021, 06:14 PM
Dick Boneske's Avatar
I've just been using a large screwdriver for the power valve on Rochester 2G carbs. The spring loaded plunger simply depresses to the bottom of the screwdriver slot. Have I missed something?
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 09-21-2021, 06:26 PM
carbking's Avatar
The plunger is not overly substantial in strength; have seen a number which are bent, and will no longer seat.
Jon.
Old 09-21-2021, 06:59 PM
Tom Vaught's Avatar
Boost Engineer
I don't do much with Rochester 2 BBL carbs these days, still have a massive number of cores though. I have two of the long Sears screw drivers with the mods Jon mentions in his post. (PV Stem Notch and straight sides.)
The Mechanic at the Pontiac Dealership pointed out that the Power Valve could be damaged as some of the Power Valves are really hard to remove.
So I made the tools, 50 years ago.
Tom V.
