Old 04-08-2020, 11:33 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Default 59 E-brake cable question
It appears that a previous owner cut my rear brake cable...on both sides.....about 12" forward...of each wheel..
So far....I've had no luck finding a replacement......
Found a listing for 1960 Bonneville....and would think it should be the same...
I believe the length....was listed at 110"....
Can anybody confirm that this will fit my 59 Bonneville?
Old 04-09-2020, 12:50 PM
694.1 694.1 is offline
The "cable" is comprised of 3 pieces. 2 two short assemblies that go into the brake backing plate & this is likely very similar to others found in the '57-64 Pontiac/Olds era. Then the cable itself, which is 1 piece and loops up front to the "puller thingy" AKA the "equalizer"... Are you talking about this main cable?
You can always grab a string & measure but I bet the '59 & '60 Bonnie are pretty darn close.
Good luck!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 04-09-2020, 02:07 PM
Good luck!
I need to seriously get underneath....and have a close rlook...at the big picture.....but can't believe that they would have changed much...on the chassis...for 1960......
Old 04-09-2020, 02:36 PM
If you need a plain cable hardware stores sell cable. Buy what you need and make one if you can't find the correct one. You can cut it to the correct length and add ends to it or clamp it to the other cable(s).
Old 04-09-2020, 05:44 PM
stevep's Avatar
stevep stevep is offline
1960 Bonneville cable should be the same.
Old 04-09-2020, 06:35 PM
Thanks...for everybodys input...
Old 04-09-2020, 07:15 PM
59safaricat 59safaricat is offline
The cables on my Safari were severed around that area on both sides. I chalked it up to the weak link in the design.
Old 04-10-2020, 12:34 AM
CATBIRD CATBIRD is offline
Green Hornet.....careful, the Bonneville rear cable is longer than the Catalina cable. Come to think of it, I just might have one that I got by mistake, and never returned. I'll look tomorrow......John
Old 04-10-2020, 09:20 PM
OK...had another look...underneath.....
Both sides are like this......
Does the replacement cable feed into the coiled strain relief?
Also spotted this tag...on the diff......Does this mean it is a Safe T Track?
ID:	536971   Click image for larger version
Old 04-23-2020, 08:20 PM
The "coiled strain relief" is part of the assembly and you will need 2. Again, likely very similar, 57-64 Olds & Pontiac.
Wish I had a parts book, Since they are pretty useless as is, maybe remove one & measure it up. Happy hunting.
7th Firebird
57 Starchief
Old 04-23-2020, 10:22 PM
Poncho60 Poncho60 is offline
If 59 is basically like 60, look at the hubs on the end of the rear axles. If you are lucky enough to find two paint swabs on one of them that might indicate a safety trak unless the punkin has been changed or a safety trak axle was used as a replacement. For 1960 a yellow / green combo was a 3.08 safety trak for example.
