Old 03-25-2020, 01:43 PM
Zappa's 68 Zappa's 68 is offline
Send a message via AIM to Zappa's 68
Default 68 Gas Gauge
Need a 68 gas gauge....rebuilding dash and the old one is rough....
Old 03-25-2020, 02:29 PM
Scott Thelander's Avatar
rally gauge or std
I may be able to help
Scott68gto@comcast.net
Old 03-25-2020, 07:25 PM
Peter Serio's Avatar
Default Fuel gauge.
This one?
Name:	1968 Lemans Tempest GTO Fuel Gauge good used_EA.jpg
ID:	535369   Click image for larger version
Name:	1968 Lemans Tempest GTO Fuel Gauge good used_EB.jpg
ID:	535370   Click image for larger version
Name:	1968 Lemans Tempest GTO Fuel Gauge good used_EC.jpg
Peter Serio
Owner, Precision Pontiac
Old 03-25-2020, 07:27 PM
Standard....thank you
Originally Posted by Scott Thelander View Post
rally gauge or std
Old 03-25-2020, 07:30 PM
Exactly Pete...I'm shopping for the best looking one I can find...I hope to never upgrade the dash again!
Originally Posted by Peter Serio View Post
This one?
Old 03-25-2020, 07:33 PM
email dpowell1166@gmail.com
Old 03-26-2020, 02:49 AM
That '68 instrument panel is a bugger to R&R ain't it?
Old 03-26-2020, 07:29 AM
Beige1968GTO Beige1968GTO is offline
Default Gas gauge
I also have a spare I can part with but won’t be able to get to it until this COVID thing is over. . . .
Old 03-26-2020, 07:45 AM
Tim john Tim john is online now
I am pretty sure I have a nice one and can look it up this evening and report back to you. Is an F body the same as an A body for this gage ? Pretty sure what I have is out of a 68 Firebird. Please PM me if you are still in need.
Tim john---
Old 03-26-2020, 11:57 AM
Understatement of the year....! But we will succeed
Old 03-26-2020, 11:58 AM
Right on....keep me in mind and be safe
Old 03-26-2020, 11:59 AM
Thanks Tim (john)
Tim john---
Old 03-26-2020, 01:48 PM
Verdoro 68's Avatar
I've become quite an expert in '68 dashes having taken mine apart 4 or 5 times in the last few months to get my gauges and dash dialed in. I dreaded that project for months, but I've done it so many times I feel like I could do it in an hour now.
I'd bet most of the used gauges you'll find will be aged and the marks will be discolored to some degree. I thought my original was in perfect condition until I looked closer, you can see how it's discolored compared the gauge face. For whatever reason the smaller fuel, oil and temp gauges seem to discolor faster than the faces. You may consider having Pete Serio restore your original depending on your expectations.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
Old 03-26-2020, 02:58 PM
dataway's Avatar
dataway dataway is offline
I have a plan in my head to bench test my whole dash unit before installing it .... hook up the fuel sending unit, temp sensor, oil pressure sensor .... whatever I can. Try to power it up and check as much as I can .... is this possible?
Old 03-26-2020, 04:42 PM
According to the box I have mine in, it was removed from a 1968 Firebird, it is really nice but does not appear to be correct for your application and does not match Pete's photos. Sorry I was not able to help you out.
Tim john---
ID:	535416   Click image for larger version
ID:	535417   Click image for larger version
Old 03-27-2020, 01:41 AM
I've had mine out, I think, three times. The last time I put it back in when everything was just as I wanted it cosmetically, the tach suddenly was reading about 1/4 the actual speed. I just didn't want to take it back out again and it's still off by that much to this day.
Old 03-27-2020, 02:45 PM
Verdoro 68's Avatar
I don't know about the dash as a whole, but you could certainly check the gauges and the light circuit individually with a 12v source. I bench tested my fuel gauge by wiring it up directly to the battery and adding an extra fuel sending unit in line.
Ken
Old 03-27-2020, 03:48 PM
dataway's Avatar
Luckily I'm just dealing with idiot lights. Would be nice if I could power up the entire dash from a single 12V input ... but I'm sure it's got a different power wire for every function. I'll probably get blisters from the alligator clips.
