Old 04-07-2020, 03:00 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Truly a very old thread, but I've got a couple of comments.
To me, a "kickout" is full-length and full-height- the "kick out" begins at the passenger-side pan rail of the block (not merely an extended section of the original pan's sump, as in post#3). This does require special means for bolting to the passenger-side block rail, but it can be done. The custom Hamburger's pan on my V8 hemi has threaded plugs below each of those bolts to pass a socket & extension through.
It makes more sense to me to use the one-way screen (from Moroso or whomever) as a fitted windage tray, rather than just on the kick-out entry. The photo is what I made from the Moroso screen for my hemi four-cylinder. [By the way, the "kick out" in this engine was free- the unused four bores of the V8 block have passages to drain the "kicked out" oil harmlessly to the bottom of the pan to be scavenged!]
Old 04-07-2020, 06:51 AM
mysticmissle's Avatar
Canton will make the bob maxey pan fwiw. At least a couple years ago when i emailed them some pictures of one they said would. Its not in a catalog, but they will make custom just like Moroso.
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
The Following User Says Thank You to mysticmissle For This Useful Post:
Old 04-07-2020, 11:24 PM
Dragncar Dragncar is offline
Steffs sent me some pics of their street pan. The race pan is a lot like it but the passenger side has a kickout that is even with the side of the block. They make one for stock 69 GTO frames.
Only thing is right now even my Canton pan hits the tips of the front main cap studs. I can heat it up and use a ball pein to do that. Any aluminum pan needs to be made that way from the start.
I am going to trace out the profile of the front cap as it all sits on the block and send it to Stan so it will be made to fit.
I see the aluminum pan omits some pan bolts. Must not be a issue.
But it has the kickout I want, proper baffles with accel and decel trap doors and the one way windage screen built in. It uses plugs like Jack referred to for access to the side passenger pan rail bolts.
ID:	536671   Click image for larger version
Name:	DSCN1056 - Copy.jpg
ID:	536672   Click image for larger version
ID:	536673   Click image for larger version
Name:	DSCN1058 - Copy.jpg
Old 04-08-2020, 06:29 PM
I have a profile of my front cap on the way to Steffs. A good pan is worth HP. This 461, I will try and have all the little things done to get a big number for what it is.
I have a V pump but was not planning on running it. Thinking about it now. There is power to be had there also.
Question, I have the classic file fit rings already. .062. To take advantage of a V pump would running back cut low tension rings be needed ? Are they available in that size ? 4.155- .062
And its already balanced. But I can not imagine the minuscule difference in weight between rings effect the balance much.
Old 04-09-2020, 02:05 AM
Thanks for the pics of the Maxey Pan in the For Sale section Brian. They asked me for pics. I could not find any.
Now I have another option, thanks ! I will shoot them to Canton and see if I can jog someones memory.
Old 04-09-2020, 12:27 PM
RA462's Avatar
RA462 RA462 is offline
This might be of interest to you.
http://forums.maxperformanceinc.com/...71#post4260371
http://www.aroilpans.com/
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
Old 04-09-2020, 06:30 PM
Originally Posted by RA462 View Post
Thanks for the link. The reason I am interested in the Bob Maxey pan is I know his works. He was a engineer and Pontiac nut and designed a great pan.
The one for sale here seems to be lacking the trap doors for launch and deceleration.
Canton has told me they can make me a pan with the big kickout and the trap doors I need as well as the one way windage screen. The Steffs pan looks like it omits some bolt holes. Less bolt holes with aluminum's different expansion rates vs iron has me concerned about leaks down the road. They look very nice though.
Old 04-09-2020, 10:15 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I don't know much, but I now have four of these oil pans from Bob Maxey and they are all identical to the one Slowbird just sold. Fwiw
I should add we've never had any bearing issues whatsoever with these pans.
Go fast, see Elvis!
Old 04-10-2020, 12:15 AM
slowbird's Avatar
slowbird slowbird is offline
An old post with Maxey pan pics. Looks just like the one that was sold. Im sure dragncar knows what he's talking about thought
http://forums.maxperformanceinc.com/...9&postcount=13
Old 04-10-2020, 02:35 AM
Scott Roberts Scott Roberts is offline
Why dont you go dry sump at the blindingly high h.p. level you're shooting for? Just cut up a stock pan to catch the oil and weld in some fittings for scavenging...
Old 04-10-2020, 06:53 AM
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
I have run a Moroso 20490 pan for years and never had a problem. I have found that you don’t need a ton of crap in the bottom of your pan to make it work. Years ago I had a fabricated aluminum pan on a Small block Chevy. It had 3 trap doors and baffles everywhere. It was a big pile of garbage. I spent so much time and money trying to get it to work. I should of just went dry sump and I would of saved a bunch and time and frustration.
Old 04-10-2020, 08:39 AM
slowbird's Avatar
Gach's pan looks just like mine.
http://www.pontiaczone.com/forum/showthread.php?t=17516
Old 04-10-2020, 05:10 PM
Best advice you can give me is "write a check". You are the King after all.
See, I gave you a compliment. I am nice.
Old 04-12-2020, 01:12 PM
455firebird1969's Avatar
Originally Posted by slowbird View Post
Link doesn’t work for me, can you post the picture?
Old 04-12-2020, 03:10 PM
slowbird's Avatar
Lol that's awesome Gach blocked the thread
Old 04-12-2020, 03:13 PM
slowbird's Avatar
Good thing i took screen shots. Here are his pics
ID:	537119   Click image for larger version
Old 04-12-2020, 03:20 PM
charlie66's Avatar
Whats is the main benefit about this pan?
My Half AN Injun.....
  #38
Old 04-12-2020, 04:14 PM
slowbird's Avatar
For it's time it was the best commercially available pan. Full length kick out, good windage control. Its probably the best steel pan if you can get your hands on one.
  #39
Old 04-12-2020, 07:04 PM
charlie66's Avatar
What is the kick out for ? I really have no idea .
That pan looks new . Is that and old picture?
  #40
Old 04-13-2020, 12:48 PM
Tiger Paw Tiger Paw is offline
D-car, if I were in your shoes. I would fabricate a pan that splits. This way you'd be able to baffle tightly to pump, thereby preventing slush up the on launch. The baffle would fastened from the bottom after upper pan went on before the sump is bolted on.
-Definitely full length kickout
- Decel baffle or trap door
-Directional screen tray
