1965 Post Door
'64 - '65 Post driver's door. Loaded with internals, wing, and side glass. $259 plus shipping will remove glass and ship that seperately. Dave S dona Ana NM 88032
Is the aluminum trim around the outside of the door/window in good condition?
64-65 Pontiac A post door Hollander #1726
Can take some closer look / pictures but to be honest am trying to sell this whole for a local yard. It is not mine. The car it came from is long gone - likely was crushed in the early/mid eighties.
Looks like a '66 door to me.
The upper door hinge is aluminum. Never parted much first gen A stuff, thought aluminum door hinges ended in 65. Hollander shows 64 - 65 interchanging then 66 - 67. For door hinges. Post trim all there, but has yard damage. This door may have been loose in yard for thirty five years. Just saying but it is solid on bottom pinch weld. Hinge areas and latch areas good. No inner panel speaker cut outs.
The reason I suspect it's a '66 door is because in '67 they started using a stamped steel upper hinge, not cast like the one you have. Another minor difference is with the door bumpers 66 to 67.
The reason I know it's not a '64 or '65 door is because of the outer skin. Note the contour of a '65 door. I'm not trying to nit-pick your ad, just thought it would be helpful to point out the year differences. |
The Following User Says Thank You to newmexguy For This Useful Post: | ||
66 Post door, Drivers' side
This drivers door assembly still available. Thanks. Dave S dona ana NM 88032
Greyhound shipping available. |
to the top.
Still available, to the top.
66 Post Door, Drivers' for sale.
To the top.
