Old 02-13-2020, 12:22 AM
Verdoro 68's Avatar
Default Legendary vs. PUI Seat Covers and Door Panels
Swapping out my old PUI door panels and seat covers with Legendary replacements. The door panels were from the mid '90s and the seat covers from 2004-ish, so I'm not sure how they compare to PUI quality today, but there's a noticeable difference between the two.
Door panels: the PUI units are much puffier and less rigid than the Legendary replacements. The Legendary units are more like I remember the originals.
Legendary panel installed:
ID:	531768   Click image for larger version
ID:	531769   Click image for larger version
ID:	531770   Click image for larger version
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 02-13-2020, 12:26 AM
Verdoro 68's Avatar
The Legendary seat covers have deeper pleats, but still not quite as deep as I remember the OEM covers. Overall the vinyl and materials are thicker and much better quality than on the old covers. You can see where the PUI cover was starting to split, the construction on the Legendary is much more robust in that area so I don't anticipate that happening with these.
PUI cover - notice that lack of depth in the pleats.
PUI on the bottom, Legendary on the top
The PUI covers were tearing near the back corner:
Legendary covers look more robust in that area with thicker padding on the side.
ID:	531772   Click image for larger version
ID:	531773   Click image for larger version
ID:	531774   Click image for larger version
ID:	531775   Click image for larger version
Ken
Old 02-13-2020, 12:28 AM
Verdoro 68's Avatar
Will post some more pics once I get them installed, but they look like a nice upgrade so far.
ID:	531777   Click image for larger version
Ken
Old 02-13-2020, 06:10 AM
dataway's Avatar
dataway dataway is offline
Very nice upgrade I'd say. And you just decided me on what brand I'll be getting. Legendary looks WAY better.
Old 02-13-2020, 01:01 PM
OG68 OG68 is offline
I inherited "Distinction" (from OPGI) interior panels and covers when I bought my car back. I have already installed the bucket seat covers and definitely don't care for them. I have a Legendary bench seat cover on my ELCo and the difference is night and day between the two. Legendary will be going into the Goat.
2007 Cadillac SRX
Old 02-13-2020, 01:25 PM
Legendary here too...
ID:	531815   Click image for larger version
Old 02-13-2020, 01:43 PM
dataway's Avatar
That looks absolutely OEM ... maybe better.
Old 02-13-2020, 05:58 PM
Greg,
Did you buy the complete kit for your door panels or did you use the original upper frame?
2007 Cadillac SRX
Old 02-13-2020, 08:50 PM
I used my original uppers. They were surface rusted but completely solid and cleaned up pretty well with some phosphoric acid. They are attached by a method most won't be able to duplicate. Maybe you guys have seen it but there are square shaped holes punched through the metal upper and the four points...think the four spaces in an 'X' are imbedded into the heavy cardboard panel.
For some reason, I can't attach a pic right now. If I could, I wouldn't have been so wordy.
Anyway, I started looking for some type of rivet that would work and ran across some two piece rivets that are usually used in leatherwork. Like the rivets you see in a belt where it folds over the buckle, purse strap, etc. All you need is a drill to make a row of new holes, a small hammer and a solid base for an anvil.
Old 02-13-2020, 08:56 PM
Verdoro 68's Avatar
I reused my uppers with the PUI panels and used short pop rivets to attach the cards. I bought pre-assembled panels from Legendary figuring they had the proper machinery and materials to do a better job than I would. Pricey for sure, I suppose that's the laziness tax.
Ken
Old 02-14-2020, 04:05 AM
dataway's Avatar
I'm up in the air about my door panels, The OEM pieces look pretty good, a bit of mildew, but are solid. I kinda like that old car smell
Old 02-14-2020, 10:51 AM
If you like them I see no reason to change them. I only dyed my rear seat cover because it was in good shape. The rest I replaced.
Sent from my moto g(6) play using Tapatalk
Old 02-14-2020, 11:23 AM
Unfortunately my panels were all baked in the California sun. Thanks Greg for the ideas. I have a spare set of panels, maybe I'll practice with the Distinctive Industries set and see how it looks. If I fubar it I'll buy the preassembled.
2007 Cadillac SRX
Old 02-14-2020, 11:30 AM
Verdoro 68's Avatar
Greg- how does your original rear seat cover compare to the Legendary covers in the front? Specifically curious how the pleats compare. My memory is of the pleats being more squared and a little deeper, but I could be wrong. That memory comes from spending hours with a toothbrush trying to clean the seats when I got the car
Ken
Old 02-14-2020, 07:29 PM
I think they match perfectly in pattern. Also, the SEM dye matched the new Legendary stuff absolutely spot on. Had to get it from TCP Global as SEM told me that their codes didn't go back that far.
I'll try to post pics again later tonight.
Old 02-14-2020, 10:03 PM
Try this again...
Ok, all of this except the console cover came with my car and I dyed it all. The cover was new and black. SEM makes a good product. It has lasted for 8 years with no peeling or chipping.
The 'rivets' I used..
ID:	531952   Click image for larger version
ID:	531953   Click image for larger version
ID:	531954   Click image for larger version
Old 02-24-2020, 12:45 PM
Verdoro 68's Avatar
Plot twist - it turns out the old seat covers are from Distinctive Industries. Huh. Now that I think about it, I remember ordering them from OPG and being really unhappy. Maybe because I was expecting PUI.
I uncovered an interesting technique when disassembling the seats. Rather than hog ringing the listing wires to the upper seat frame, the upholstery shop attached a few inches of muslin in several places, fed that through the foam, pulled it tight and hog ringed it to the frame.
Got the rear seat and part of the passenger seat done. Got a few blisters from clipping old hog rings and installing new ones, and my upper body is getting a work out from all the stretching. They're looking good though. Legendary has a number of install videos on YouTube that were helpful.
ID:	532894   Click image for larger version
ID:	532895   Click image for larger version
ID:	532896   Click image for larger version
Ken
Old 02-24-2020, 01:54 PM
dataway's Avatar
Your progress is shaming me, I'm uncomfortable, I need my safe space
Old 02-24-2020, 06:20 PM
Verdoro 68's Avatar
I have an anxious 12 year old urging me to complete this project because car show season is approaching. Also, the longer parts sit out in the garage, the more questions my wife asks
Ken
Old 02-24-2020, 09:08 PM
Zappa's 68 Zappa's 68 is offline
Send a message via AIM to Zappa's 68
Legendary here....no issues really!
ID:	532951   Click image for larger version
ID:	532952   Click image for larger version
ID:	532953   Click image for larger version
ID:	532954   Click image for larger version
