Old 03-03-2020, 08:40 PM
duke455's Avatar
duke455 duke455 is offline
Default 70 TA scoop ques8
Just acquired an original 70 trans am scoop everything is intact except someone cut the tabs of the side that held it to the air cleaner does anybody reproduce those tabs these are the ones that are spot welded on..thanks
Old 03-03-2020, 08:45 PM
Drop a PM to PY member Norwood. Craig should be able to fix you up.
Old 03-03-2020, 09:17 PM
duke455's Avatar
Default Scoop
Thank you
Old 03-11-2020, 05:10 AM
duke455's Avatar
Default Scoop
Bump
