Old 03-19-2020, 08:18 PM
Dadspackard's Avatar
Dadspackard Dadspackard is offline
Default 1969 GTO HOOD (Drivers Side)
Hello All,
Have an issue with the my hood on my 1969 GTO where when I go to close the hood the drivers side rear edge of the hood drops and rubs against the fender (it has caused some chipping on the edge of hood and on fender) ).
Is this an adjustment issue or are the hinges weak?
I am going to be placing an order from NPD and they have this hinge or this hinge which one would be best to order that is if you all think my hinges are bad.
Tom
Old 03-19-2020, 10:59 PM
Ram4king's Avatar
Ram4king Ram4king is offline
Hinge is shot.
If you decide to go with original ones I have a few sets ...125.00 plus the ride
Old 03-20-2020, 03:57 AM
Kenth's Avatar
Kenth Kenth is offline
Missing bumpers on cowl?
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-20-2020, 07:27 AM
Ram4king,
That is what I figured just wanted some second opinions before I order new ones. Thank you very much for the offer on the original sets.
Kieth,
Bumpers are there.
Name:	1969 GTO Engine.JPG
Now that I will be ordering new hinges should I go ahead and get spring too?
Hood stays up fine.
Name:	1969 GTO Exterior Right.jpg
Name:	1969 GTO Passenger Side Interior.jpg
Name:	1931 Pacakrd.jpg
Old 03-20-2020, 08:39 AM
Old Goat 67's Avatar
I'd stick with originals.
Old 03-20-2020, 09:16 AM
dataway's Avatar
dataway dataway is offline
First make sure both hinges are well lubricated. A sticky hinge on one side will cock the hood to the other side when you close it. You can usually spot a worn hinge by opening the hood and getting someone to rock it back and forth while you watch the hinge pivots.
Old 03-20-2020, 09:17 AM
When I hear originals to me it sounds like ones taken off a car.
So when you all are talking originals are we talking NOS or ?
If buying news ones from OPI, Ames or NPD (which are the from Ames) is that not the way to go? I am all ears then.
Ram4king,
Could you post some pictures of the ones you have?
Old 03-20-2020, 09:25 AM
Dataway,
That is exactly what it is doing the drivers side would drop/close cock as you described. When I get back out to where it stored I will give the hinges a good lube first and see what happens.
I really do appreciate the feedback. Dont want to spend unnecessary cash if I don't need to. Could use it for other things under the hood, Trans cooler lines, Radiator shroud, straps for the holding the wire-loom etc...
Old 03-20-2020, 09:38 AM
Half-Inch Stud's Avatar
Half-Inch Stud Half-Inch Stud is online now
Yea, a combo of things to get well:
Need Hinges with tight rivets
Need a SQUARE hood-fender-Front Bumper-hood gapping, not racked like a paralellogram.
Need Tight Radiator-Support bushings.
and perhaps need tight Body-mount bushings under the Firewall.
Then the Fender-Hood rubber wedges can be chosen wisely to mitigate "Hood-Shake"at idle and driving.
Old 03-20-2020, 09:58 AM
Ram4king,
Just saying, I have read and heard horror stories of reproduction ones that are totally junk!
My 67 GTO hinges are as good as new because I've always kept them oiled once or twice a year since new.
The Following User Says Thank You to Old Goat 67 For This Useful Post:
Old 03-20-2020, 12:36 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
Good advice here on lubricating, checking hood/fender/radiator alignment and ensuring that the hinge pivot points are tight. There is one other very important reminder to offer regarding hood closure procedure.
When closing a hood, one does not pull down on the hood from the front edge. NO - do not do that! How many kinked hoods do we see from that process with a tight hinge? Instead, one should place hands on the front edge of the hood and push the hood back toward the windshield. This process moves the hood in concert with the motion of the hinge and shifts the stress away from the area of the hood structure that incorporate crash windows (68+).
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
The Following 3 Users Say Thank You to 68gtoMN For This Useful Post:
Old 03-20-2020, 02:37 PM
All,
Thanks for the awesome advice everyone. Only wish I had the GTO back here at home in Illinois. I'd be working on it today since we have been sent home to work from home the last week and maybe longer.
GTO needs some minor work for me to drive it back from Indiana.
One thing I found the other day while I was out working on it some previous owner cut the Trans cooling line near radiator and then spliced in some rubber tubing which is kinked in an S shape. The cut metal line is ready to break trough the rubber line at the S. Urggg Sure glad I spotted it before driving it back.
Be safe and keep healthy everyone.
Old 03-21-2020, 02:45 AM
Inline Tube has the cooler lines. I replaced mine a couple of years ago and fit was not drop-dead perfect but fit well with a little flexing here and there.
Old 03-21-2020, 09:01 AM
dataway's Avatar
Make sure you look into WHY the lines were cut. Could be the fittings were just frozen in the radiator. Or if the fittings are still in the radiator and looped together it could mean the trans cooler was leaking and coolant and trans fluid were swapping places.
Sometimes if the cooler inside the radiator is rusted out people will put a loop on the lines to the tranny, and then leave the fittings in the radiator with a stub of tubing and loop those too.
Old 03-21-2020, 10:56 AM
Dataway,
I did not get to deep into to looking as to why the one line was cut but as you stated it is possible the lines are frozen in the radiator.
There is no looping of the lines. The lines are attached to radiator and run back to the trans.
Greg,
Did you go with the stainless or the carbon steel lines?
Old 03-22-2020, 09:19 PM
Greg,
I have no idea. Didn't even know that they offered two types. How do you tell?
Sent from my moto g(6) play using Tapatalk
