Old 03-22-2020, 10:50 PM
Dick Boneske's Avatar
Default Accelerator Linkage for '61, '63-'64, & '65-'66
I need pictures of the linkage on the intake manifold driver's side rear for the accelerator linkage. I believe there are three varieties. '61, '62-'64, and '65-'66.
No one reproduces these parts. I have some '61 pieces, but no later ones.
The first picture is of a '65. The other two are '62.
Name:	Kodak 4330 Camera 1-19-10 118.jpg
ID:	535092   Click image for larger version
ID:	535093   Click image for larger version
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 03-23-2020, 10:19 AM
pfilean's Avatar
pfilean pfilean is offline
Pictures of 61 B body.
ID:	535128   Click image for larger version
ID:	535129   Click image for larger version
ID:	535130   Click image for larger version
ID:	535131   Click image for larger version
Old 03-23-2020, 10:20 AM
pfilean's Avatar
One more just for good measure.
Old 03-23-2020, 12:57 PM
8LUG 8LUG is offline
Default linkage
1964 fullsize
Old 03-23-2020, 09:39 PM
Thank you pfilean and 8LUG. The first two must be '61--they were the simplest setup, even with automatic trans. The '62 and later used the rubber grommet as shown on the '64 picture.
As I said, we're looking for parts for the '62-'64 and '65-'66 for a restoration and possible reproduction as these parts are scarce and not reproduced.
BONESTOCK GOATS
Old 03-24-2020, 10:09 PM
67GP428's Avatar
67GP428 67GP428 is offline
Here's my 65 linkage setup. Not sure if 100% correct? If someone sees something incorrect, please let me know. If more pictures wanted let me know.
ID:	535264   Click image for larger version
ID:	535265   Click image for larger version
1965 Pontiac 2+2 421 HO auto
1967 Pontiac Grand Prix 428 4 speed- sold
1968 Firebird 400 auto - sold
1967 Bonneville Brougham 2 dr. hardtop. 1969 AMC Rebel SST wagon-sold
Old 03-25-2020, 12:35 AM
Thank you. Great pictures. I like how you handled the kickdown switch-putting it on the rear carb instead of trying to crowd it between the center and rear carbs.
Here's how we did it on this '66 setup--moving the slider to the front carb to make room for the switch. I like your way better.
ID:	535278   Click image for larger version
BONESTOCK GOATS
Old 03-30-2020, 10:20 AM
I found the '64 & '65 brackets. Will media blast them. I think those pieces should be bright zinc (silver).
Has anyone found a source for the rubber bushing that holds the rod from the firewall linkage? I don't believe the old one can be removed without destroying it. Besides, 55 year-old rubber is not what it once was!
BONESTOCK GOATS
Old 03-31-2020, 06:22 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default Accelerator Linkage rubber bushing
Is this the bushing your asking about?
I found this out in the garage today & thought it may be a part to a full size Pontiac.
Any help in identifying the year or years it belongs to would be appreciated.
The round hole in the rubber bushing is just a wink over 5/16" in diameter.
Name:	1960s Pontiac big car Accelerator Linkage bushing_E3.jpg
ID:	535902   Click image for larger version
Name:	1960s Pontiac big car Accelerator Linkage bushing_E2.jpg
ID:	535903   Click image for larger version
Name:	1960s Pontiac big car Accelerator Linkage bushing_E1.jpg
ID:	535904   Click image for larger version
Name:	1960s Pontiac big car Accelerator Linkage bushing.jpg
Peter Serio
Owner, Precision Pontiac
Old 04-14-2020, 06:57 PM
Peter, That's a '65/'66 bracket. I finally found two of them. Now, I need to determine if they were plated or painted. I believe they were plated like the '61-'64 brackets.
The attached pictures are of both versions, the '61-'64 and the '65/'66. When I posted this initially, I thought there were three different versions, but now have found there are only two.
Anyone know about painting or plating?
Thanks.
ID:	537331   Click image for larger version
BONESTOCK GOATS
