Old 04-07-2020, 10:12 AM
killakev's Avatar
killakev killakev is offline
Default 1968 GTO Manual Trans. Console Wiring
Hey guys,
I'm wondering in particular where the switch and light land on a manual trans console? I found a diagram in the Restoration book where it shows a switch (Plunger type) mounted on the front console lip to activate the light as the console door is opened. Wondering about this style switch and where the light socket lands. The socket is separate, not like a glove box switch/light that has the bulb on the opposite side of the switch. I don't see anywhere obvious where the light is supposed to be mounted.
Anybody have any pictures of theirs?
Old 04-07-2020, 11:04 AM
gto4evr gto4evr is offline
it is exactly like the glove box light. the setup pushes down through a hole on the top where the plunger contacts the door. the light just hangs down inside and there's a hole drilled through the console box insert that lets the light shine in. It was a crappy design, didn't give much light and had problems with the light not going out, plunger breaking off, etc. They ended up eliminating that soon afterwards on the 69-72 consoles so if you've got a later insert box it might be missing the hole for the light to shine through.
Old 04-07-2020, 11:51 AM
I should also have mentioned that the 68-72 manual consoles all look the same from the outside so you may not have a 68 base either, so the switch hole itself could be missing if it's a later console.
Old 04-07-2020, 11:58 AM
killakev's Avatar
I do have the hole for the switch but I guess the insert may have been changed since I don't see any hole for the light socket to insert into.
Where is the light socket hole exactly?
Old 04-07-2020, 12:11 PM
Scott Thelander's Avatar
it shines thru a hole in the console liner
and
70 -72 will have a lid latch rectangle hole cut in the top lip also
Old 04-07-2020, 12:22 PM
dmorg1's Avatar
dmorg1 dmorg1 is offline
this is a 68 manual console
Dave
http://www.stellarmachine.com/
68 GTO
68 LeMans
68 LeMans Convertible
79 Firebird
Old 04-07-2020, 12:38 PM
killakev's Avatar
Oh so it is just a glovebox switch/light! I guess I was thrown off because I actually have a seperate light socket. I guess that was added
Thread Tools
Display Modes
