1980 Turbo Pace Car tank to pump fuel line pic
Hi,
I have a 1980 Turbo Pace Car I am putting the engine back in from a rebuild The tank to pump drivers side fuel line I have now is cut at about where the door hinges are on the frame rail below I ran a fuel line from the cut to the pump area but it goes threw some funky bends on the control arm area and where it passes through the firewall fender area I am going to get the inline tube 2 piece kit tomorrow Does any have a detail picture or photograph of the line from the pump out so I can see the routing as where it goes threw the engine compartment drivers side to the frame below As Always thanks again |
Do you have the 1980 Assembly Manual?
I have it
I am going to check now |
I just checked no detail from fuel pump to frame
OK I'm looking at a few right now.
Couldn't see any specific for 301T, went through 4 manuals. Is it turbo specific? May be the same as 301 in a 77, of which I have none of these models. Or just the Pontiac engine version.
I can check my 81 pacecar but im pretty sure the lines are the same as other mid to late 70's 2nd gens with pontiac engines. Can you take a pic of the area youre describing so im know what to look for?
Sounds like its the short section that runs under the frame/upper control arm area then on to the pump. |
Not sure how similar this may be, as it is of a 70, but hopefully of some assistance.
1970-74ish have the fuel lines on the passenger side, all later year pontiac engine 2nd gen firebirds have the fuel lines on the driver side... totally different routing.
The Following User Says Thank You to 78w72 For This Useful Post: | ||
