Old 07-18-2019, 04:51 PM
DM3 DM3 is offline
Default Halogen headlight suggestions
I have been talked out of LED and HALO headlights by two friends.
I am going to go to halogen headlights. I would like to be able to replace the bulbs, any suggestions out there?
I would also like the high beam lenses to be amber.
Thanks DM3
IG: #67MoparBird (Follow my rebuild)
1967 Firebird 400
Appeared on Gearz, Season 16, Episode 1, Segment 'What Are You Working On?'
Old 07-18-2019, 07:08 PM
OG68 OG68 is online now
https://www.danielsternlighting.com/.../products.html
Daniel Stern has been around for a long time and is known for quality Cibie products.
He may also have a line on amber lens.
2007 Cadillac SRX
Old 07-19-2019, 01:27 PM
92GTA's Avatar
92GTA 92GTA is offline
I have no suggestions for Halogen, but if you decide to do LED "PROPERLY" with the right type of bulb in the right type of housing, I went with these:
https://www.amazon.com/dp/B00GUPLFMQ
https://www.lasfit.com/products/ls-p...eadlight-bulbs
Most people are idiots and put the wrong type of bulbs in housings that weren't meant for them and they blind people. I HATE those dicks.
1969 Pontiac Firebird
Old 07-20-2019, 08:36 PM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
Any experience with the Octane lights?? LED or hallogen ...
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 07-30-2019, 11:22 AM
Zyman's Avatar
Zyman Zyman is offline
Thanks DM3
Problem with halogens is they are yesterday's tech and you need to run relays to draw current directly from the battery (added cost). If you do not they do not get enough power from your stock wiring. The best solution I found was this LED product https://www.cjponyparts.com/headligh...-1969/p/HLA55/ It has the added benefit of providing both the headlights and bright lights at reasonable cost.
"Pride Precedes The Fall"
1968 Firebird Undergoing Transformation
1970 Formula 400 - Keylime Green, Stroked to 462 Cubes - Gone But Forever Remembered
2016 Mustang GT - GT with the Performance Pack, beats my former 12 Boss around the track.
Old 07-31-2019, 09:44 AM
DM3 DM3 is offline
Here are the headlights I went with, both are halogen with replaceable bulbs. I was told they are direct replacement, no additional wiring required.
Low Beam: United Pacific Crystal Round Headlight 5-3/4",
https://www.jegs.com/i/United-Pacifi...31386/10002/-1
High Beam: Octane Lighting - Single - 5-3/4" Halogen Amber Yellow Glass Headlight Fog Light H4 60W Light Bulb
http://vi.raptor.ebaydesc.com/ws/eBa...71286000&ver=0
Both needed some modification. I didn't want to modify the existing light housing so I modified the light instead. Both needed some grinding and/or modification. Both have glass lens and metal body.
The pictures are a test fit and will need additional fitting to sit correctly.
ID:	516868   Click image for larger version
1967 Firebird 400
Old 07-31-2019, 10:00 AM
Zyman's Avatar
DM3 - those look like a good choice. My understanding of the current requirements for halogen bulbs is that while they will "work" with stock wiring, they will not perform to their designed level due to lack of available current. I installed similar halogens on my 2nd gen and they were notably better performing after installing relays to draw direct from the battery. Perhaps others could comment.
Old 07-31-2019, 12:01 PM
DM3 DM3 is offline
If they are not bright enough, maybe I can find LED lights that fit the lighting housing and replace them down the road.
DM3
1967 Firebird 400
Old 07-31-2019, 01:02 PM
JLMounce JLMounce is offline
This is my understanding as well. Even the sealed beam stock type lights can benefit from the use of a relay.
I'm still waiting for Dapper Lighting to release their OE glass 5.75" Once that happens I'll be going that direction more than likely.
At this point currently I actively avoid driving the car at night, especially on a dimly lit highway at speeds above 50mph. It's simply not safe with sealed beams and the factory wiring.
-Jason
Old 07-31-2019, 01:37 PM
XLR8STEVE's Avatar
XLR8STEVE XLR8STEVE is offline
Use 2 relays, one for low and one for high beams. Easy to do. Really improves lights. I usually tuck them at the drivers side of the radiator support where they can not be seen.
[SIGPIC]
Steve
Old 07-31-2019, 05:58 PM
Do you have a rough wiring schematic on that deal?
-Jason
Old 08-09-2019, 03:53 PM
Try this http://www.madelectrical.com/electri...adlights.shtml GREAT site for anything electrical. Beware if you call. Mark will talk you to death ... LOL
Old 08-20-2019, 11:39 AM
First Bird's Avatar
First Bird First Bird is offline
I did a Hella E-code conversion, these are European spec headlamps.
Halogen bulbs are replaceable and as bright as you want.
Relays are mandatory if you don't want a fire.
The guy at www.rallylights.com was helpful. This was 8 years ago but they're still in business
- Tom
Old 08-20-2019, 12:04 PM
Lee's Avatar
Lee Lee is offline
Lots of BAD LEDs, but there are some good ones as well.
Start with this video: https://youtu.be/peFLmu2MfTg then maybe watch some of his other stuff.
These are what I will most likely install in my '73 in the near future: https://www.ebay.com/itm/Anzo-881035...53.m1438.l2649
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
