Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 05-04-2019, 01:35 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
Default Cold Case 12" Dual Fans Setup
Hey guys - I bought these a few months ago and never installed and have decided to stick with the clutch fan. This is the set up for a 1964 GTO radiator. New in box, includes two fans, aluminum shroud and wiring harness with temp sensor. $250 shipping included.
Old 05-04-2019, 01:36 PM
with image
Old 05-04-2019, 09:32 PM
bendutro bendutro is offline
Will it fit a '67?
I can't find the product on Cold Case's site.
Old 05-04-2019, 10:13 PM
If the 67 radiator is a different size than the 64, which I suspect it is, then the shroud may not work, but I don’t know for sure. Here is a link to the radiator it fits, the fan kit is an option on this page (open the item choices and u will see it).
https://www.coldcaseradiators.com/pr...mance-radiator
Old 05-04-2019, 10:30 PM
All ‘64-‘67 A-body V8 radiators will interchange size wise, the upper inlet locations are different. There are two different radiator core heights, 17.5” for A/C and heavy duty cooling and standard 15.5”. Both different heights require a corresponding core support to accommodate that difference.
I used a ‘67 radiator in my ‘64 years ago, 17.5” core with an A/C core support.
Old 05-05-2019, 03:13 AM
Dragncar Dragncar is offline
What would it take for it to fit a 69 ?
Old 05-05-2019, 07:58 AM
In the case of this part, I don’t know if the fin/vein area which I think the shroud fits on top, is different for the 67 or 69
Old 05-05-2019, 09:48 PM
GTO3DEUCES GTO3DEUCES is offline
The COLD CASE radiator website is totally ‘wonky’, meaning that it’s best viewed on a PC or a MAC. They’re relational database, for lack of a better word, sucks. They’re search engine sucks as well. Just call or email them to ask for the proper link to the fans, radiator, or shroud your interested. They manufacture for practically any and every car.
*** NOTE ***
Many of their part numbers cross-reference. So for example: A 1966 Chevelle, will cross to a 1966 GTO. Also, they’re part numbers cross within manufacturers. i.e. our GTO at hand.
Old 03-28-2020, 02:39 PM
Hey guys - I was going through the garage and bringing this one back. Trying to clean out space. Again, this is the dual 12 inch electric fan set up with aluminum shroud and wiring harness. This is for a 64 or 65. New in box, never used. New this is about $320 for everything. Putting it back on market for $150 plus shipping from Pelham, NY.
add this as option on this radiator if you want more details on the kit...
